20 Most Recent Dell Dimension 2400 (24006YYVP31) PC Desktop Questions & Answers
I can't connet to messenger. Hotmail works and
Check after disabling your antivirus software.If you need suitable assistance you can also get online technical support. I would suggest you to contact TheBestPcDoctor. I get my issues fixed by them.If you need you may also contact them @www.thebestpcdoctor.com or via 877-407-9229
1/17/2017 10:50:01 AM • Dell Dimension... • Answered on Jan 17, 2017
Hp dvd 1040 wont be recognize my PC..Someone help me!
Power on computer and enter the set up (BIOS) menu by tapping the F2 key. Hold down the <Alt> key and depress the <E> then the <F> keys in succession. This will force the motherboard to load default settings and also force the motherboard to redetect all IDE devices. Note: The selection for the floppy drive will be set to ON. If you do not have one then you must disable floppy in set up (BIOS) menu.
11/2/2013 1:15:52 AM • Dell Dimension... • Answered on Nov 02, 2013
Disk 0 seek failure
You must re-install windows or whatever OS your machine came with. If you have a windows CD, boot from that and follow the instructions given.
9/23/2012 10:47:12 PM • Dell Dimension... • Answered on Sep 23, 2012
How to upgrade ram?
HERE and HERE are the two pieces of info you need directly from Dell specific to your model PC.
8/25/2012 11:26:32 PM • Dell Dimension... • Answered on Aug 25, 2012
I have a Dell Dim 2400 and no connection with HP Deskjet 3070A.
Charles, has this combination worked previously, have you been able to print from your Dell Dimension 2400 to your HP Deskjet 3070A successfully?If the answer to the above is Yes, then if you believe that the printer is still working correctly and you can test this with a different computer able to print to it, you should consider uninstalling and re-installing the HP software and device drivers for this printer.If you have not printed to this printer successfully previously, have you tested the printer with a different computer and proven it is still working fine?If the printer works fine to a different computer then providing you are using the same USB cable to connect to your Dell 2400, the problem needs to be narrowed down further.Check that you can plus other USB devices into the port on the Dell used for the HP printer - if these work, then your USB port is good - if not, try another port if you have one.If your USB hardware is good, then again you are left with the need to uninstall and re-install the HP software and device drivers - it may be worth trying to download the latest version of such software if available. HP tend to update their All-in-One software on a regular basis.
12/31/2011 12:06:11 AM • Dell Dimension... • Answered on Dec 31, 2011
I have no sound card for my computer
Please purchase sound card and install it on your PC... thanks
8/14/2011 7:09:19 AM • Dell Dimension... • Answered on Aug 14, 2011
Hello, I have been having trouble with my
Sounds like your hard drive crashed. You'll need to replace the hard drive.
6/1/2011 7:50:57 PM • Dell Dimension... • Answered on Jun 01, 2011
2answers
Why is DVD drive not working?
9/13/2023 6:36:09 PM • Dell Dimension... • Answered on Sep 13, 2023
Ack graphics card wont fit in any input slots
the adapter u are using is pci express and the dell dimension 9100 are not compatible.. try returning it for either a pci (usually the white slot) or AGP which in most cases is brown.. the AGP will be your best performance.. if return is not an option.. then it seems that a new pc is in your best interest.
2/6/2019 7:31:43 PM • Dell Dimension... • Answered on Feb 06, 2019
On my DELL Deminsion E110 the video downloads are sporadic and jerky, but audio is good
Audio is easy...requires little ram to operate. Video today needs 2 GIGABITS or more for VIDEO. A lot depends in the Motherboard Processor also. If it is old, the main processor is no doubt slow. High speed internet is faster than some computer speeds and thus the computer is trying to buffer (catch up) which causes means conditions to occur. Lag time with Video is one problem. Windows operating system is another. Win 8-10 are ok, but older OS's are slow. THEN we have a Video Card problem. Old cards require new drivers to keep up with changes. Some old Video is slow because the VIDEO RAM is too slow and old. Solution = a New 2018 Computer
1/31/2018 11:27:45 PM • Dell Dimension... • Answered on Jan 31, 2018
When I turn on my Dell DM061 (Windows Vista)
all these symptoms can be from ram stick fault, graphic card or graphic section of the mother board or a failing hard drive you will probably have to have it properly diagnosed by a computer repair shop to find out exactly the failing component
3/25/2017 9:12:10 PM • Dell Dimension... • Answered on Mar 25, 2017
Why my dell 4700c desk top. have dotted horizontal lines on start up?
Try securing the connection between the computer and the display. Try pushing the connector into the ports on both ends. If there are screws on the connectors, make sure they all of them are tightened.
12/13/2016 11:03:17 PM • Dell Dimension... • Answered on Dec 13, 2016
Dell 4400 boots up to Dell logo and then freezes.
You will have to start. By servicing. Your pc . Add me on facebook for a guide on how to service. Your own pc. A pc must get new thermal compound every 3 months
9/20/2016 9:05:19 PM • Dell Dimension... • Answered on Sep 20, 2016
Restoring my computer dell dimension 5150to factory setting
1 Turn on the computer. 2 When the Dell splash screen appears during the computer startup process, press and hold <Ctrl> and then press <F11>. Then, release both keys at the same time. 3 In the Dell PC Restore by Symantec window, click Restore. Alternatively, press <Tab> to highlightRestore, and then press <Enter>. 4 When a warning message appears stating that all data will be lost, click Confirm, or press <Tab> to highlight Confirm and then press <Enter>. The Progress window will appear. Once the restore process starts, Dell PC Restore by Symantec usually takes about 8 to 10 minutes to finish. When the restore process is complete, the following message will appear: The system recovery process was successful.
7/2/2016 7:37:51 PM • Dell Dimension... • Answered on Jul 02, 2016
Lost emails
Likley still on your email providers 'server' .. Log-in using a web browser (Firefox whatever) If you can't find them ij the 'In-box', look in the 'deleted' folder
3/30/2016 11:26:08 AM • Dell Dimension... • Answered on Mar 30, 2016
I NEED THE SWITCHES DIAG. FOR DELL 33007 MOTHERBOARD WITH A 462 SOCKET
Preston Hendrickson, Unfortunately, Dell does not have any switches diags or manuals to provide for motherboards. Thank You, Dell-Jesse L
1/13/2016 3:06:36 PM • Dell Dimension... • Answered on Jan 13, 2016
Dell 4600
When editing the BIOS if you go into the BOOT ORDER menu, it is possible that the network card is not showing as an option. In order to get this option to display, go into the "integrated devices (legacyselect options)" and then select the network interface controller. Edit that even if it is On and change it to On w/PXE. After saving the changes to the BIOS, you need to power the computer off then on and then go into BIOS again, and the "integrated NIC" option should be available in the BOOT ORDER menu. Set this to be the first boot device in order to use PXE.
11/6/2015 3:19:21 PM • Dell Dimension... • Answered on Nov 06, 2015
Dell Dimension 2400 (24006YYVP31) PC Desktop Logo
13 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
Dimension Dell
  • Dimension Dell
Most Popular Question
disk 0 seek failure
  • Computers & Internet
