20 Most Recent Acer Aspire™ T135 PC Desktop Questions & Answers
Aspire ahows green light but won't start up, have turned off main but still just green shows
Pull the plug from the AC outlet, wait a 30 seconds, plug in, try to reboot. Does it try to start and in a few seconds shut down? Give as much detail as you can.
12/21/2012 11:42:30 PM • Acer Aspire™... • Answered on Dec 21, 2012
Video card upgrading issues
Once the Video card is inserted the motherboard, it automatically selects the video card and at the BIOS settings just select the one with an AGP selection, then boot up the computer. Install the driver that comes with the video card. It might also ask you to restart... just select Ok then its done.
6/13/2012 3:53:53 PM • Acer Aspire™... • Answered on Jun 13, 2012
It turn on but it doesn't detect monitor, keyboard, mouse
ok its unusual for all those periphrials to go out at same time. it sounds like a mother board issue . you may need to service or replace you board.
11/13/2009 3:37:48 AM • Acer Aspire™... • Answered on Nov 13, 2009
Cannot burn pictures to a
change the dvd drive, it mean the dvd lens is weak
10/16/2009 7:04:42 PM • Acer Aspire™... • Answered on Oct 16, 2009
Acer Aspire T135 desktop.
best to u it is your OS error you install your xp .........or other vision.
2/18/2008 6:10:37 PM • Acer Aspire™... • Answered on Feb 18, 2008
Acer Aspire E1 571 not charging battery.
Question edited for clarity and toss in a few CAPS. Question moved to Acer Aspire category. There a few issues that can cause this, the obvious one is that the battery has failed internally, but it can also be a charging software issue. Try this. Unplug from the mains supply. Remove the battery. Leave the computer for 2 hours. Press and hold the power button for a full 2 minutes. Replace the battery, plug back in, count to 10 and power it back up. Has the motherboard battery ever been changed? They are critical to the health of the motherboard and the machine in general.
Aspire E1-571 Plugged in not charging
Acer Community https://community.acer.com > ... > 2016 Archives Aug 20, 2016 - Hi, I have been having a quite critical issue with my laptop recently.
Acer Plugged In Not Charging
Driver Easy https://www.drivereasy.com > ... > Common Errors Apr 21, 2021 - This plugged in not charging problem may occur if you are using the wrong battery driver or it's out of date. So you should update your battery ...
Acer E1-571, Charging problem
Tom's Guide Forum https://forums.tomsguide.com > threads > acer-e1-571... Feb 10, 2019 - Hi there, I have a acer e571 laptop and i am facing a battery charging problem, whenever i plug in charger it start charging for 10 to 15 seconds and start. 1 answer · Top answer: It could also be the charger. The fact that moving the cord made a difference makes me think it might be. Also, have you tried charging it when the laptop ... My acer e1 570 laptop won't charge - Tom's Guide Forum Feb 7, 2017 I have an Acer Aspire E1-571-6837. It will not charge the ... Aug 25, 2016 Hi my acer aspire E1-571 won't turn on. I plugged it in and it ... Mar 9, 2018 More results from forums.tomsguide.com ..
4/18/2024 10:53:10 AM • Acer Aspire... • Answered Yesterday
2answers
Access outlook
what password computer or outlook Reset an Outlook password to keep your program secure. A Microsoft Outlook password keeps your email account secure from unwanted intrusion. When you wish to reset your Outlook password, you must perform a multistep process to change your password first with your Internet Service Provider (ISP). The password with your ISP mail server must be the same as the password you set in your Outlook program in order to send and receive emails. Call your ISP and request a new password for your account. Write down the password after you receive it to ensure you do not forget it. Open your Outlook program, click the "Tools" tab and then select "Email accounts." Select "View or change existing email accounts" and then press "Next." Highlight the email account you wish to change (if you have more than one email account) and press "Change." Enter the new password you just received from your ISP into the appropriate fields (entering it twice). Place a check mark beside "remember password" if you want Outlook to remember your password each time you log in. Click "Test Account Settings" to make sure your account works with the new password. Press "Finish." I forgot my Outlook password http://office.microsoft.com/en-us/outlook-help/i-forgot-my-outlook-password-HA001113690.aspx
12/25/2023 6:14:52 AM • Acer Aspire... • Answered on Dec 25, 2023
My acer aspire m5100 desktop will wont do a start up beep and nothing on the screen
If you have no internal hard drive installed you won't get it to work correctly as the hard drive is where the data is stored for the operating system.
10/2/2022 2:12:57 PM • Acer Aspire... • Answered on Oct 02, 2022
Prendo la pc acer y se apaga vuelve a prender y se apaga y asi sigue
Estimado Carlos, Cuando la PC se apaga poco tiempo despues de terla prendido puede ser una senal de sobrecalentamiento del procesador. Si es una PC desktop, puedes verificar si el disipador de calor de aluminio y su ventilador estan colocados correctamente sobre el procesador y si el ventilador esta' funcionando. Si es una laptop, debes verificar si cuando la prendes el ventilador de las rejitas de ventilacion esta' suenando. Un ventilador que este' parado o con baja rotacion puede ser una de las causas del sobrecalentamiento. Pero, en los dos casos, si no es problema del ventilador del procesador, lo que hay que hacer es lo siguiente: 1 - Desarmar la computadora, y sacar el disipador de calor com mucho cuidado de sobre el procesador; 2 - Limpiar bien entre las ranuras del disipador de calor, sacandose todo el polvo y suciedad del mismo ya que el polvo ayuda a mantener el calor y sobrecalentar el procesador; 3 - Limpiar muy bien las rejillas de entrada/salida de aire, sacandose todo el polvo y suciedad, 4 - Rearmar el disipador sobre el procesador, pasando entre ellos una delgada camada de pasta termica plateada, que se puede comprar en tiendas de suminsitros y partes de computadoras (NOTA: no instale el disipador sobre el procesador sin pasar la pasta termica, porque podra' seguir sobrecalentandose); 5 - Rearmar la computadora. Caso usted no tenga facilidad en armar y desarmar la computadora, seria bueno contactarse con un tecnico de su confianza para hacer ese trabajo para usted. !Espero que esa respuesta pueda haberle sido util! PD.: Como ese sitio web solamente accepta caracteres en Ingles, la acentuacion no puede ser utilizada normalmente... Saludos, Miguel Luiz Martins
6/30/2022 3:55:50 PM • Acer Aspire... • Answered on Jun 30, 2022
Not receiving a video signal (VGA or HDMI) from an Acer i5 Intel H57 Motherboard H57D02G1 1.0-6KSMHS1
OucH no acer real model PC told at all wow hard nut to crack that, I sure can not guess that ...The case told only helps if power on button is wrongor the PSU is wrong. I moved this to acer forum. as the mobo matters.Q1;never worked before by you,? this acer mobo by you?or found it used and dead.? used mobo come good bad or a wreck. (history not told , as in when did fail)the acer.com is the place to look first. for manuals. not told what GPU are you using onboard vga or GPU card or what?All fans spin ? CPU and PSU????if using GPU card that has fan, does it spin too??if case fans do they spin?DoeS DVD tray eject (button hit)?DOES PC beep or flash LED codes?Q2;What VIDEO port class is this "connection"is it:vga, hdmi, dvi or DP ports which one, and where is it? For now only use (if has one) use the VGA port on the mobo , no PCI cards in slots., NO HDD, AND NO DVD DRIVE (JUST UNPLUG THEM FOR NOW) ALL USB THINGS UNPLUG, KEYBOARD LEAVE THERE.MEMORY :pUT 1 stick of ddr RAM only in bank0 channel "A"CPU socket pins bent as seen on ebay endless and sad. below is me guessing what Acer you have.and find this, Acer/GATEWAY ZX4951 or ASPIRE Z3100I read the GW manual check jumpers.the PSU needs 2 power cables to the mobo.4pin power and 24pin (or 20 on legacy)or mobo will be dead. why mess with ACER. (they have no service manuals)put an Asus or Gigabyte mobo there and end this ACER pain,post a photo of the mobo and we can guess what PC it came out of, .......
6/4/2022 5:10:37 PM • Acer Aspire... • Answered on Jun 04, 2022
I've had my Acer Aspire V5-531 for about seven months now and it recenetly started to make a loud humming noise every time I pick it up or just move it a little bit. It's usually going on for
mute the speakers if still sounds noisy the fan inside is packed in lint and needs to be cleaned out or overeheating is bad news. why not ask a shop to look into this. we can take it apart (covers ) and user or stethoscope to hear noise. a $5 tool that is. and all shops have one or DIY one. I put my hear to hDD casings me, i use tube and put it near the fan vent to hear it scream. there is no other way besides unplugging all that 1 by one to hear it go silent. this is SOP, vast PC's pack up in lint and fail.
5/27/2022 5:04:29 PM • Acer Aspire... • Answered on May 27, 2022
2answers
I keep getting a message popping up saying I have a problem then the app shuts down, its a new laptop and its never been used before, I downloaded the app to watch my dvds, the message says my code is
Sounds like the application is not installed correctly, uninstall it via control panel and re install from the original disc or download. If you don't have this available, you can use an alternative player, I personally use VLC and prefer it, more info here: VideoLAN Official page for VLC media player the Open Source video framework Or direct download if you prefer: http://get.videolan.org/vlc/2.1.5/win32/vlc-2.1.5-win32.exe
7/2/2021 11:21:42 AM • Acer Aspire... • Answered on Jul 02, 2021
3answers
How do I get a manual for a acre aspire es1 331
acer aspire es1-331 is the proper way to ask...correct spelling is a must. and depends on if your in USA or what your country is required.
2/12/2021 3:13:23 PM • Acer Aspire... • Answered on Feb 12, 2021
My acer aspire V3-571-6846 bluetooth somehow has
ALL THOSE PEOPLE OUT THERE SUFFERRING FROM THIS. THERE IS AN SIMPLEST SOLUTION AND THAT IS JUST DOWNLOAD ACER LAUNCH MANAGER VERSION 8 FROM GOOGLE. https://softfamous.com/acer-launchmanager/ THIS IS THE LINK AND INSTALL THIS AND BLUETOOTH ICON WILL APPEAR IN THE TASK BAR. IT WAS SO SIMPLE PLEASE TRY THIS
12/3/2019 3:41:19 PM • Acer Aspire... • Answered on Dec 03, 2019
2answers
3answers
Acer Aspire M/ The cursor disappeared and I cant get it back
first confirm that your touch pad is working or not. yor touch pad may be disabled or it may be dead. you can enable your touch pad in it's setting. you can connect an external mouse to your laptop to check that. or you can enable mouse keys in control panel.
5/13/2019 5:53:31 AM • Acer Aspire... • Answered on May 13, 2019
ASPIRE3 USER MANuaL
You'll need to be more specific. Acer makes several Aspire 3 notebooks. Many of their manuals are available here: https://www.acer.com/ac/en/US/content/drivers . In the drop down menus, choose Notebook, Aspire and look for the model number. Current Aspire 3 notebooks have model numbers that start with A315. The user manual for the A315-21 is currently here: https://global-download.acer.com/GDFiles/Document/User%20Manual/User%20Manual_Acer_2.0_A_A.zip?acerid=636564340054411702&Step1=NOTEBOOK&Step2=ASPIRE&Step3=ASPIRE%20A315-21&OS=ALL&LC=en&BC=ACER&SC=PA_6 . You'll need to extract the contents of the file to read the manual. I hope this helps. Cindy Wells
2/10/2019 2:26:50 PM • Acer Aspire... • Answered on Feb 10, 2019
Acer Aspire™ T135 PC Desktop Logo
7 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
aspire ahows green light but won 39 t
  • Computers & Internet
