20 Most Recent
Garmin Nuvi 2460 2495 2555 2595 3790 Lm W Gps Usb Hardwire Power Cable Charger Questions & Answers
Garmin nuvi says low battery and it is plugged into the car
The Garmin will tell you 'Low Battery' if its alternative power source is not available for some reason, so the battery is not being charged. Depending how the Garmin has been programmed, the display on some models will become slightly brighter when a power supply, other than its own batteries, is detected. Check for this.
It is likely that the lead you use to plug into the car is not supplying voltage to your Garmin set. If it plugs into a cigarette holder, check that the cigarette lighter works, or plug in another device to see if there is any electricity to the receptacle. Obviously ensure that the ignition switch is on. If the plug-in bit of the power cable has a light on it, check the light is illuminated. if you have a sensitive tongue, you should be able to put the end of the lead that plugs into the Garmin onto your tongue and you will feel a very slight tingle on your tongue if power is getting to the end of the lead. If not, then there is probably a break in the lead inside the plastic insulation or a problem with the supply plug.
If the plug in lead proves serviceable then you should change the batteries in Garmin as one or more may have failed and will not charge. Check for this by leaving the unit on after unplugging the external supply lead. Depending on the Garmin you have, the unit should remain functioning for at least 30 minutes. The internal batteries will degrade rapidly if the unit has not been use for some time and the batteries were not fully charged before you put it to bed.
Change to english
I recommend that you will post your question under
the correct category (GPS devices) and maybe add more details to it, so it will
be easier for Experts to understand the question and answer it.You can also contact the site directly at: http://www.garmin.com/us/support/contact
My Garmin Fishfinder 240 Blue
The --.- indicates that either the unit isn't receiving a signal from the transducer or the signal is out of the range for the unit/display.
Is the Depth Set on Auto Range and what happens if you change it to a Set Range?
Hi I recently got a
If Endomondo.com is your upload site, you are affected by this problem:
http://www.facebook.com/topic.php?uid=136072689446&topic=16004
/T
I am runningy first marathon
I have used my 405 for more than 5 hours and have not had any problems with the battery life running out. I have had mine since Apr/09. I do make sure it is fully charged before use the day of the race. I also make sure that the I found the sattelites the day before if you are running from a new location.
Hi we need a manual
Hi Linda, i have the same 1983 Travelaire motorhome Econoline F-350 26ft and are in search of the Shop/owners manual ... Do you know where to find one ?
I am located in BC Canada
Reg 250-379-2971
[email protected] if you can contact me ?
How can I maintain my pool table at top condition?
In
order to maintain the condition of your table and prolong its lifetime you
should avoid eating above the table, putting drinks of ash trends on the sides
of the table, and generally try not to harm the cloth with the cue. In addition
you can clean and vacuum the table from the outside once a month, this Is what
I'm doing to my table.
What is the price range of a quality foosball table?
Good quality and long-lasting table start at
about $600. In this case, like in many others, the more you pay, the better
quality you will get. Make sure that you're buying a known brand and compare
prices first, before you buy. It is also recommended to read some reviews about
a table or tables that you like.
