20 Most Recent
PPI DCX-1500.1 Car Audio Amplifier Questions & Answers
Ppi dcx 1500.1 is it 2 powerful 4 da 12in. L7?
Hello montyski20,
The amp outputs 500 watts RMS into 4ohms, 750 watts RMS into 2ohms and 1000 RMS into 1ohm.
The L7 can handle 750 watts RMS (375 watts per each coil). If your L7 is the 2ohm version, you should wire the voice coils in series, the positive marked coil to the negative unmarked coil. Then connect the remaining positive and negative to the amp terminals. This gives you a 4ohm load (500 watts). If your L7 is the 4ohm version, wire the voice coils in parallel, both marked and unmarked positives together, likewise both negatives and then to the amp terminals. This gives a 2ohm load (750 watts).
Paralleling the 2ohm sub will result in a 1ohm load (1000 watts) and that is too much for the L7.
Hope this helps.
I NEED A INSTALL AND
Hi and welcome to FixYa,
The installation and user's manual for the PCX series 4 Ch of Precision Power mobile amplifier including the PCX4125 is available
here.
Good luck and thank you for asking FixYa.
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
