20 Most Recent
HP Pavilion a1640n (RC663AA) PC Desktop Questions & Answers
Will not power up
Power up issues is more likely your board or power supply.
Motherboards have capacitors, check to see if it bulging or looks like it exploded from the inside. If every cap is flat and normal looking, then its good.
Power supply issue, can be only be verified with another known good working power supply. But if you have a power supply tester, you can use that to determine if it is good or not.
PC disconnects from Internet
pls check if there any virus becoz this could happen due to some heavy virus downloads or distruption. Update your anti virus software properly. There are so many viruses and Worms which can distrupt your wireless internet.
Secondly, your wireless configration software has been corrupted. pls re-install it.
Remote responds very, very slowly
Remote needs to see the device it is connecting to, try moving the desktop so the remote can see the desktop. IF that doesn't work maybe a new set of batteries... Good luck.
Two red flat wire
which one do you mean john ? if sata to the motherboard.seven teeth looks like small capital l.proberly on the side of the motherboard.
I installed windows 7 home premium; now the sound card, previously used with XP, will not work .
Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers. Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software. Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers. Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker. You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Hope this helps
It says no audio device
Possible that the audio driver of the motherboard was corrupt and so will need to be reinstalled. If you have the CD install it from the CD and run it on the PC. If not download from the HP official site and run the driver to be installed. If there is no result as the audio does not work there can be errors in the OS or a possible hardware issue.
Can I put a wireless
If it has USB ports you should be able to install a wireless USB adapter. If it has available PCI slots you can install a wireless card.
I can't get any sound on this computer. Mute is
Check if the sound card driver is installed. Check the device manager and see if there is any item with an exclamation point. You may also want to check if the speaker is working by connecting it to another device.
I just inherited an HP Pavilion a1640n desktop
Please check the power cords which are connected with your computer,and if lose fix it. If your problem is not fixed then remove the cabinet cover and try to fix the heat sink by pressing the A B tabs shown and start the pc.Thanks have a great day
Bios Help? Motherboard? How to fix?
The most likely cause is your hard drive has stopped being detected for some reason. You would need to go into the CMOS setup utility and check and see if the drive is listed there. Usually there is a shortcut key you push like F1, F2, Del, F12 (it varies from computer to computer). Start trying these keys right after powering on the PC (within one or two seconds). The actual screens also vary from PC to PC, making it difficult to describe further clarification on what these will look like.
If you're comfortable with opening your PC you can check and make sure the power and data cables are securely connected.
Sometimes inexplicably the simple act of blowing all the dust and other crud out of a PC helps with this. If you haven't done that for a while...stranger things have happened.
If all else fails you may have to buy a new hard drive and re-install your OS. Before that I would recommend taking the PC to someone who can look at it in person and really determine the issue.
I can't get a cd out of my hp pavilion
CD Drives normally have a small pinhole which you can trigger to manually eject the drive. Do this:
1. Turn off your computer
2. Get a paper clip thin enough to fit into this pinhole at the front of the CD drive.
3. Insert the paper clip into the pinhole until you see the drive eject. You may need to push in the paperclip around 1 inch or so.
NOTE: Please rate our help to keep this free service online
The Ezarc.msi can't be found in my computer
What is Ezarc.msi ? Have you done a complete search of your computer including all subdir's? If this file cannot be found, find out how useful it is and try to find it on a friends computer.
