20 Most Recent
Dell Dimension™ E510 PC Desktop Questions & Answers
No Sound
Does it have onboard sound as well, here is a link to the dell site and the manual, have a look as it does have onboard sound from Sigmatel STAC9220 so maybe two sound drivers are installed and conflicting
Why has my Dell computer gotten very slow? I have
If you have a lot of internet cookies it can slow your system down. Your computer stores virtually everything that goes onto it. Go to MY COMPUTER double click and go to your C: drive. Right click and go down to PROPERTIES click on it. Go up to TOOLS. Click on it and go to DEFRAGMENT NOW. Run that and see if it helps.
I have a dell dimension E510 computer it turns on
What exactly can you see on the screen?
A blinking cursor?
Entering power saving mode?
Try to unplug the cables and plug it back in,it should work.
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
On a dell e510 at
This means that your pc regognize a floppy disk in the drive, tried to boot from this floppy and the floppy is not bootable. You have 2 solutions:
- Remove the diskete from the floppy drive and restart. Assuming that your hard disk is ok the pc will boot normally.
- You have to enter the bios and change the boot order. Doing this you will change the boot priority and the pc will try to boot from the hard disk before the floppy drive. Since this solution it's more complicated from the first one, I suggest you to follow this way in case you are familiar with bios.
In case of a problem or clarification, or more details for the 2nd solution, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Drive opens up, but does not read anything
Could be a dirty lens, try a CD lens cleaner or a blast of compressed air from a can.
It may also be worth taking the case off (Disconnect the power first) and checking that the ribbon is connected properly at both ends.
PC won't startup
either your ram or cmos cell is damaged,
Firstly remove one ram and power on it
Secondly change the cmos cell which ois on the motherboard
My Dell Dimension E510 cannot pick up any voice
This sounds like you have a voice morphing program installed. A morph program is useful for distorting your voice and special effects, but it also takes over your mic controls. Go to the control panel and choose sounds and audio devices, then look for the default device under sound recording and make sure your record device is the same model as your sound device and that it says INPUT. Another problem occurs if you right click your little sound/audio icon on the taskbar and choose open volume control then left click. Do that now and choose, options, then properties. Now on mixer device, choose one that says input. The white window on the bottom of that panel will show you several devices, check mark them all and click ok. Now manually select MIC as your default sound input device and close then try again.
My SOUND CARD software has been erased. I need to
please tell following:
is your sundcard on board or
is it add on soundcard
if on board
go to manufacturer site download drivers and run setup
if add on
go to manufacturer sire download drivers and run setup
else if
the drivers are not found
register on site driverguide.com for free
download drivers
run setup
have a nice day and don forget to give me all thumbs
if still not working please tell in detail
Dell Dimension E510 - Keyboard compatibility
Hi, to find out if the “Keyboard is compatible with your system?” You can do the following: Shutdown the Computer, connect the Keyboard to your computer. Turn on the computer. If, the “Keyboard have a Power Button?”(Turn on) the keyboard. Go to, Control Panel; click on Device Manager. Click to open Keyboards, in the (Keyboard Properties) Click on Driver (Box), next click to Update Drivers! Click OK. Restart the computer. Check keyboards’ functionality. Thanks paul7of9
