20 Most Recent HP Compaq Presario SR2180NX (RK548AA#ABA) PC Desktop Questions & Answers
5answers
Changing Vista to XP Pro on a Compaq Presario SR2180NX Desktop PC
SR2180NX has the Vista 32Bit OS from HP. The restore partition will always put Vista 32Bit back on if you use it. Windows XP can only be put on from scratch and I have done it while I still have Vista installed. One problem: there are no XP drivers under SR2180NX webpages. Do your research on the parts that are installed in the 2180 and any other HP machines that have the Windows XP operating system as the OEM OS. But First, check the Intel Site for the 945 chipset drivers (include the SouthBridge, too) under XP. Get them downloaded to a CD and burn the rest of the drivers you find for XP on the same CD. This way, you will have them ready when you are performing the down-grade to windows xp. After you are done with the XP install, you will still have access to the files & work you had done while in Vista. The Vista files are still readable. You might want to consider getting the Windows 7 Professional (not basic) available October 22, 2009. AND you will still have to get the Intel Downloads for Win7 any way, so why not make it a project and make it last for a few years. XP Support stops in 2014.
3/8/2016 5:16:09 AM • HP Compaq... • Answered on Mar 08, 2016
Trying to find a cheap HDMI graphics card to put in. Any suggestions? Also, is it necessary to upgrade the power source?
This particular computer has an PCI-E slot available for a graphics card upgrade (provided that it doesn't already have one in there). You should be okay with not upgrading the power supply, unless you're looking to put a really beefy card in there. Something simple, that'll have HDMI on it and will have no issue driving HD content would be best in the realm of a Geforce GT 720. It's $50 on NewEgg. http://www.newegg.com/Product/Product.aspx?Item=N82E16814487062 Hope this helps!
8/28/2014 10:33:54 PM • HP Compaq... • Answered on Aug 28, 2014
If you want to look at bad HDMI pictures, then go for a cheap graphics card. If you have maxed out memory capacity and have no more room for hard drives, then get a larger capacity power supply.
8/28/2014 8:06:36 PM • HP Compaq... • Answered on Aug 28, 2014
Why my pc no longer reads my sd card
Try another SD card. If it works, the card is damaged. Also, see... http://www.instructables.com/answers/Compaq-sd-card-reader-not-working/
7/30/2014 9:18:01 PM • HP Compaq... • Answered on Jul 30, 2014
Pci device
Which device? Please be more specific.Try re-installing the intel chipset driver.This usually happens if the chipset drivers are not all installed properly.
7/26/2012 3:41:30 PM • HP Compaq... • Answered on Jul 26, 2012
Beeps when is turning on
You need to be more specific... How many beeps? Did you add any new hardware? Were you doing anything inside the case? Does it boot up at all? Are there any messages on the screen?
6/26/2012 3:40:51 AM • HP Compaq... • Answered on Jun 26, 2012
Bepps when turning on
You need to be more specific. How many beeps? Did you add any new hardware? Were you doing anything inside the case? Does it boot up at all? Are there any messages on the screen?
6/26/2012 3:40:41 AM • HP Compaq... • Answered on Jun 26, 2012
What causes a blue screen?
ram issue if safe mode. otherwise turn apps on one by one to see which one is causing it. u can also try load the drivers one by one in safe mode to see maybe a driver is crashed or conflicting with some system code.
3/2/2012 2:21:20 PM • HP Compaq... • Answered on Mar 02, 2012
I have to press my power on plug/button for several seconds before it comes on and the computer still does not fully power up. My monitor is black and does not come on. I have put in a new power sup
Sounds like your video card to me. If you have an add-on card, it can be replaced. If you have one that is integrated into the motherboard, you can add a card if you wish. I'd go for a new motherboard. If one part of the board failed, what is next?
2/21/2012 12:37:48 AM • HP Compaq... • Answered on Feb 21, 2012
HDD not detected
try to remove the hard drive and try it unto another pc... probably cable problem. if not, maybe faulty hard drive . :(
7/8/2011 4:55:32 PM • HP Compaq... • Answered on Jul 08, 2011
Recientemente conecte la Pc a
Usted puede tratar de arrancar en modo seguro pulsando F8 durante el boods m?quina. Una vez en modo seguro se puede tratar de hacer una restauraci?n del sistema de la, en Inicio, Todos los programas, accessores Herramientas del sistema • Restaurar sistema. Si esto no funciona, entonces usted tiene que hacer una restauraci?n completa del sistema o la recuperaci?n del sistema en funci?n de su computadora. La mayor?a de los nuevos equipos le permitir? hacer una recuperaci?n del sistema pulsando una de las claves durante el arranque. Usted va a perder todos los programas y todo lo que est? en el equipo. Usted puede ser capaz de hacer esto sin tener que formatear el disco duro. I’m happy to help further over the phone at https://www.6ya.com/expert/al_e83b1941f9c0f302
4/4/2011 9:25:47 PM • HP Compaq... • Answered on Apr 04, 2011
How do i take off the cover of a Compaq Presario
Instructions are found here:
3/25/2011 5:00:40 PM • HP Compaq... • Answered on Mar 25, 2011
No video response and beep code, one short and one
On HP, one short and then one long beep usually means a problem with memory. Open up the case and try reseating the memory. If you have more than one, you can try removing them one at a time, trying to boot up each time and see if you can isolate which one is bad.
12/14/2010 3:48:00 AM • HP Compaq... • Answered on Dec 14, 2010
No video response power to
Please disconnect all the peripherals, then remove the RAM. Leave the computer idle for five minutes and reinsert the RAM. clean the RAM slots with air blow. Then reconnect the peripherals and restart the computer
12/14/2010 12:07:15 AM • HP Compaq... • Answered on Dec 14, 2010
Registry corrupted, no recovery cd available. what
you could run the check disk utility click start run type cmd then type chkdsk/r/f which willscan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive hope this helps
11/13/2010 12:07:51 AM • HP Compaq... • Answered on Nov 13, 2010
Ok my computer wont boot
Three causes
Bios is not set to boot from CD first
CD is not properly burnt as bootable (often the case in pirate copies of software)
CD rom drive is dying.
8/4/2010 4:10:30 AM • HP Compaq... • Answered on Aug 04, 2010
My computer stays on
If the Pc is booting directly to safe mode and the OS windows XP than Simply uninstall the SP3
7/10/2010 7:11:20 PM • HP Compaq... • Answered on Jul 10, 2010
I want to add a video card upgrade to my Compaq
NO you would need a extra power supply or upgrade your power unit to at least a 500 WATT see Hp jips its customers and puts a 350 watt or a 400 watt in there systems so then you are not going to have the connectors to power that card in the pci E slot. So you will need to unfortunately upgrade the power supply. its for your benefit to do so anyhow.
Any questions let me know, please do click the accept button for my efforts. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
4/27/2010 3:36:40 AM • HP Compaq... • Answered on Apr 27, 2010
I have a hynix 512MB 1Rx8 PC2-5300 240-pin
yes, the ram is backwards compatible.
12/27/2009 12:46:45 PM • HP Compaq... • Answered on Dec 27, 2009
HP Compaq Presario SR2180NX (RK548AA#ABA) PC Desktop Logo
Popular Tags
34 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Presario HP
  • Presario HP
Most Popular Question
pci device
  • Computers & Internet
