20 Most Recent Epson PictureMate (C11C556001) InkJet Photo Printer Questions & Answers
4answers
My pad is saturated... any ideas
It will only take 10 min to get to the sponge, i can send you pix from the service manual if you want!
10/6/2016 12:29:16 PM • Epson... • Answered on Oct 06, 2016
2answers
Code:P error message: Pad saturated.. ink leaked..replace cartridge
Hi!!
Chances are the printer needs maintenance, you can actually send it to a repair center to replace the inkpads for your printer, try this link for information and you can download as well the utility from this site after registering:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Your printer has a one year warranty if its still within the warranty call epson if not try this site www.epson.com/loyalty and try the passcode minute or market and register. Hope this help. pls dont forget to rate solution. Thanks!!
10/5/2016 9:38:46 AM • Epson... • Answered on Oct 05, 2016
2answers
Replaced ink, nothing prints not even tests
there are two main areas of concern: A waste sponge2c905eb.jpg located just under the printhead, and which helps to park the printhead when you turn the power off, and the actual printhead itself. There are also two ribbon connectors that attach to the printhead assembly--and if one of them is not fully plugged in the exact symptoms you describe will occure.
To reach the waste sponge require the dis assembly of the upper half of the printer. I can knock it out is about 5 minutes now! I have used about 50 Q tips to soak up the ink, and manually clan the long rectangular sponge as well.
It you want I can send you pictures of my printer all torn down.
11/10/2013 10:17:32 PM • Epson... • Answered on Nov 10, 2013
2answers
Error close cartridge door
I had the same solution until I realised that if you look on the left hand side of the cartridge drawer there is a small white plastic "lever" that if you push in you will see that the screen changes to the normal one. It would appear, in my case anyway, that I must have broken something off which stopped the lever from being pushed in when I closed the door. So, I put a piece of Blu-Tac over the lever and closed the door and hey presto all is working. Hope this works for you. Max
9/11/2013 1:27:42 PM • Epson... • Answered on Sep 11, 2013
Epson picturemate deluxe I installed a new ink cartridge but the screen says there is no cartridge.
It can be various reasons like.. Didn't remove protective tape on cartridge.Didn't properly seat cartridge.Contacts on carriage need to be cleaned.You can clean them by cleaning the contacts on the old "empty" cartridges, then installing/removing them a few times.**If you need any kind of technical assistance you can contact support cell at here
1/24/2013 8:35:09 AM • Epson... • Answered on Jan 24, 2013
2answers
Epson cx5500
go on to this link and your reseter software is there http://indoreset.blogspot.com/2008/02/epson-cx5500-cx5505-i-knew-u-want-it.html
5/17/2012 3:07:31 AM • Epson... • Answered on May 17, 2012
0answers
Hi! I can not get my
Be the first to answer 8/19/2011 3:44:15 AM • Epson... • Posted on Aug 19, 2011Be the first to answer
Machine powers up displays one
Could you please clarify with more details? I would like to know how and from which program you print your photos. Are you printing from your computer or from your Camera or from your memory card or etc..? As per you've described above, it looks like you are trying to print from Memory Card, if so, once the memory card is inserted and is loaded, don't ever press the Left Selection button, i.e. the "Select All" button, instead use the left right arrow button and locate the picture, once it's located, press Ok, nothing else, no Up Down keys. I would also suggest you to press the "Print Preview" button to make sure you've selected the correct picture. Make sure you see the number of selected photos on the top right corner of the screen, if one photo is selected, you'll see 1, if two photos then 2 and so on. If you think you've selected more than one photo, press the "Copy" button to deselect the current picture. If you are in the multi thumbnails view of your pictures, you'll see the selected photos are highlighted with orange frames, if your view mode is single photo view, then you'll see the orange border around the photo.
Note: Never press Ok or any key once the photos are loaded, instead press the left or right arrow keys to select the photo you want to print.
If you need further help, please let me know with the details I've asked above. If you are printing from your computer, don't forget to mention the Operating System and the name of the program from which you are trying to print eg. Photoshop or Windows Print wizard, etc..
Also, is this the first time you try to print like this or have you been printing like this recently, have you ever had this problem before (if you've printed photos in the similar way you are printing this type)?
Good Luck.
Thanks for using FixYa.
7/19/2011 7:39:04 PM • Epson... • Answered on Jul 19, 2011
Just put new Epson ink
http://www.retrevo.com/support/Epson-PictureMate-Printers-manual/id/259ag808/t/2/
Please find you manual above.
It was first suspect that your head on the black, is faulty, and the only way to test and to tell is to try a new cartridge, if this doesn't work, and cleaning makes no difference, then usually in these cases the most likely thing is you have a blockage in the little tubes between the cartridge and the nozzle itself, this is quite common, this mean that to fix it, the entire assembly must be replaced. Now as for the colors being all wrong, this points to a bad "Engine" inside? and if we put the two problems together then I think, that it is all got to do with that, the internal electronics, I think that you have a problem with the "Computer" inside the printer, and it isn't controlling the print heads correctly? the only fix in that case will be a main board replacement?
There is little anyone can do with printers these days, the days of DIY are gone, for the most part, and the very best thing to do, is get a free "Quote" as to costings for a repair, and go from there? get it looked at by an Epson professional ONLY.
6/26/2011 3:19:44 AM • Epson... • Answered on Jun 26, 2011
Will not work in vista
Go to http://www.epson.com/support and see if you can download vista drivers for your model printer.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
6/25/2011 10:53:21 PM • Epson... • Answered on Jun 25, 2011
Can you Help me unclog
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
5/18/2011 6:58:52 AM • Epson... • Answered on May 18, 2011
I need soft ware and
To get the Drivers and Software go to: http://www.epson.ca/cgi-bin/ceStore/support/supDetail.jsp?BV_UseBVCookie=yes&oid=40942&infoType=Overview
If that is not your exact model then do the following:
  1. On the top of the website hover your mouse over Drivers & Support
  2. Click Printers & All-in-Ones
  3. Under the list below the picture, choose Single-Function Ink Jet
  4. On the right side list choose your PictureMate model
  5. The screen that loads will contain all the links you need for drivers and software.
Hope this help!
5/12/2011 6:46:21 PM • Epson... • Answered on May 12, 2011
All my picture from my
Hi!
You need to run a Head Cleaning cycle so printer can get rid of the old ink from your previous cartridge. Try running it from maintenance for at least twice or try printing pictures in between cleaning cycles.
Hope this helps.
5/5/2011 11:09:10 PM • Epson... • Answered on May 05, 2011
No Problem, just want a manual!
First of all, here is the main Epson ONLINE SUPPORT page:
http://www.epson.ca/cgi-bin/ceStore/support/SupportIndex.jsp?BV_UseBVCookie=yes&oid=-10237&infoType=Overview
And here is the support page for the generic version for your model:
And here is the direct link that Owner's Manual / User's Guide:
http://files.support.epson.com/pdf/mate__/mate__u1.pdf
If you have a specific model of PictureMate printer such as the CHARM, SNAP, or ZOOM edition, then you will have to select it yourself from the list provided at the main support page.
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated or the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there.
Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
If this was at all helpful please click on the 4 Thumbs Up helpfulness rating icon you see on this page.
Thank you very much and good luck.
Joe.
3/2/2011 2:50:06 AM • Epson... • Answered on Mar 02, 2011
0answers
Error message 0043
Be the first to answer 1/29/2011 2:28:47 PM • Epson... • Posted on Jan 29, 2011Be the first to answer
A new ink cartridge placed in the printer and
First check the cartridge to make sure you removed the protective plastic that is usually on the it. If this is a seperate ink/head unit. Clean the printheads with a cottonswab and alcohol then do a test print.
1/23/2011 8:40:12 PM • Epson... • Answered on Jan 23, 2011
The Epson Picturemate doesn't recognize
Hello.
Try the memory card in another device (printer or computer) to be certain it is not faulty.
From Epson, here are the supported Card Slot devices: CompactFlash Type I & II, Memory Stick, Memory Stick Pro, Memory Stick Duo^, Memory Stick Pro Duo^, Magicgate Memory Stick, MagicgateMemory Stick Duo, Memory Stick Micro^, Microdrive, SD card, Mini SD card^, MicroSD card^, SDHC card, Mini SDHC card^, MicroSDHC card^, MMC, xD-Picture Card, xD-Picture Card Type-M, xD-Picture Card Type-H
Note that ^ indicates that the card requires an adapter
Hope this helps.
12/31/2010 7:03:12 PM • Epson... • Answered on Dec 31, 2010
Epson PictureMate (C11C556001) InkJet Photo Printer Logo
71 questions posted
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
PictureMate Epson
  • PictureMate Epson
Most Popular Question
pad saturated any ideas
  • Office Equipment & Supplies
