20 Most Recent
Ricoh Aficio™ SP-C210SF Printer Questions & Answers
How can I convert Ricoh development counter to pages
Best thing to do is contact Ricoh Services and Support (1-800-432-9787) for service. A Ricoh Tech/Engineer would need to go into Special Service to change the Accounting type preferences, as end-users shouldn't have access to this Special Service function. Additionally, once this change has been made, you cannot revert back; you can only change this setting once.
How can I check the
The instructions for getting the page count for the C210SF should be the same as for the C231SF:
- Press
User Tools.
- Scroll down until you see
Reports Print.
- Press
OK.
- Scroll down to either
Configuration Page (2 pages long, prints in black and white) or
Maintenance Page (1 page long, prints in color).
- Press
OK.
Both the configuration page and the maintenance page will show the page counts. For page count instructions on other models of copiers or printers, check out
ConfigPages.Blogspot.com.
I have Ricoh Aficio MP c2800, Machine say toner undetectable all four when i check system status and yellow, cyan is not show up on copies at all
If your Ricoh Aficio MP C2800 is showing "toner undetectable" messages for all four toner cartridges and the yellow and cyan colors are not showing up in copies, there may be several potential causes for this issue. Here are some troubleshooting steps to help you resolve the problem:
- Check Toner Cartridges: Ensure that all four toner cartridges are correctly installed and securely seated in their respective slots. Make sure there are no protective seals or tapes left on the cartridges.
- Shake Toner Cartridges: Sometimes, toner inside the cartridges can settle or clump, leading to detection issues. Gently shake each toner cartridge side to side to redistribute the toner evenly.
- Replace Toner Cartridges: If the toner cartridges are old, empty, or expired, replace them with new, genuine Ricoh toner cartridges.
- Clean Contacts: Dust or debris on the toner cartridge contacts can interfere with communication. Use a soft, lint-free cloth to clean the electrical contacts on both the toner cartridges and inside the printer.
- Check Developer Unit: The developer unit in the printer plays a crucial role in toner development and transfer. Ensure that the developer unit is clean and free from any obstructions.
- Perform a Firmware Update: Check if there are any firmware updates available for your Ricoh MP C2800 printer. Updating the firmware might address known issues and improve printer performance.
- Reset the Printer: Power off the printer, unplug it from the power source, wait for a few minutes, and then plug it back in. Power the printer on to see if the issue resolves.
- Check Toner Detection Sensors: The printer uses sensors to detect the presence of toner cartridges. Verify that these sensors are functioning correctly and not blocked by any debris.
- Perform a Factory Reset: As a last resort, you can try performing a factory reset on the printer. However, be aware that this will reset all settings to their defaults, and any custom configurations will be lost
