20 Most Recent Lexmark X1290 All-In-One InkJet Printer Questions & Answers
I don't have the cd to download
Yes, you can download it.You can download the Lexmark printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
7/19/2012 7:50:28 AM • Lexmark X1290... • Answered on Jul 19, 2012
Computer won't detect printer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/nJ7AgN. Select your operating system, download and execute the file.
2/14/2012 9:52:30 PM • Lexmark X1290... • Answered on Feb 14, 2012
Printer will not print fom computer MY PRINTER IS
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
10/30/2011 4:07:07 AM • Lexmark X1290... • Answered on Oct 30, 2011
CAN NOT SAVE IMAGE
It could be that the computer that you're using has some restrictions to guest users or non-Admin users. Try to ask the owner or the Admin for the security settings or the restriction settings to allow you to make or create files.
I hope this helps.
10/20/2011 10:36:21 PM • Lexmark X1290... • Answered on Oct 20, 2011
I lost my software and tried to download the
Please visit the Lexmark website to download and install the printer driver on your computer. Try this link: http://bit.ly/nJ7AgN. Select your operating sytem > click on "FILTER" > click on the printer driver under Recommended Downloads. Download and execute the file. Follow the instructions on your computer screen.
10/12/2011 8:40:34 PM • Lexmark X1290... • Answered on Oct 12, 2011
Lexmark X-1290, will not Print
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
9/13/2011 5:51:32 PM • Lexmark X1290... • Answered on Sep 13, 2011
I installed new cartriges 26
1.Remove the protective tape from the cartridges: With the printer powered on, open the front cover of the printer. The cartridge carrier should move to the middle.Remove the cartridge(s) from the printer.Look on the underside of the cartridge(s). If there is yellow tape and/or transparent blue tape there, remove it. 2.Clean the cartridge nozzles: Go to the Lexmark Control Program or Solution Center and run the Clean print nozzle test.Examine the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right, with no gaps.If there are gaps in the lines, you could run the Clean Print Nozzle page a few more times to try and clear it up . 3.Reset the ink levels: Lexmark printer cartridges do not have ink sensors. The levels of ink are produced by a mathematical calculation of ink drops and page counts.The printer stores this information. Ink levels can be reset by "telling" the printer that you have installed a new ink cartridge or by reinstalling the printer drivers. Download and install the printer's driver: Windows 32-bit
Windows 64-bit
9/3/2011 3:03:36 PM • Lexmark X1290... • Answered on Sep 03, 2011
I just purchased a new computer and have
Please visit the Lexmark website to download and install the Lexmark X1290 Printer Driver on your computer. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
9/2/2011 4:45:06 PM • Lexmark X1290... • Answered on Sep 02, 2011
No tengo el OCR para
La Lexmark El software de OCR análisis sólo puede ser instalado utilizando el disco de instalación de Lexmark que viene con su impresora. Si usted no tiene el disco o la has perdido, tratar de comunicarse con el Centro de Soporte Técnico de Lexmarkpara obtener ayuda.
Nota: Esto se traduce utilizando translate.google.com.
9/1/2011 5:57:57 PM • Lexmark X1290... • Answered on Sep 01, 2011
Como armar una impresora lemark
No estoy seguro si estoy siguiendo.
Haga clic en este enlace para descargar la Guía del usuario de Lexmark X1290 es el sitio web de Lexmark.
8/2/2011 3:15:12 PM • Lexmark X1290... • Answered on Aug 02, 2011
I hooked my printer to
Make sure the fax software is installed on the other computer. Use the installation disc that came with your printer to install the software. Also, your computer should be connected to a phone line. A phone connection is required for faxing to function.
7/13/2011 6:56:58 PM • Lexmark X1290... • Answered on Jul 13, 2011
It comes on but wont
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Disconnect your printer from your computer. Reboot your computer. When the printer comes on, reconnect it to your computer. Try to print again.
You can also try to re-install the printer driver on your computer.
7/13/2011 5:52:59 PM • Lexmark X1290... • Answered on Jul 13, 2011
I need a 16 black
Staples, Office Max, Office Depot, any number of places online just Google it
6/1/2011 6:38:24 PM • Lexmark X1290... • Answered on Jun 01, 2011
Lexmark x1290 prints blank pages.
Please refer to this article on how to clean the cartridge nozzles: Blank Pages Printed.
5/4/2011 6:52:02 AM • Lexmark X1290... • Answered on May 04, 2011
What kinda ink does my lexmark x1290 take
Apparently this particular printer is no longer on the market. The 1270 is listed and appears to be the same printer except it's white instead of black. The cartridges listed for that printer arelexmark 16, 17, 26, or 27.
Hope that helps.
4/10/2011 1:44:58 AM • Lexmark X1290... • Answered on Apr 10, 2011
Lexmark X1290 All-In-One InkJet Printer Logo
131 questions posted
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
X Lexmark
  • X Lexmark
Most Popular Question
  • Office Equipment & Supplies
