20 Most Recent
Canon ImageClass D861 Printer Questions & Answers
Paper jam from bottom tray.
You might have a piece of paper out of sight. It usually is before the toner and after the pick up area. BEst to call 800-ok canon to find a local service center. This unit comes with a 3 year warranty, and you might still be covered.
E000000 0000 ir3300
The fixing assy is not reaching temp fast enough, lamp blown or thermal cutout.
Paper jam???
Follow these steps :
1.1
Remove all paper from the trays. This will prevent further jams during the clearing.
2.2
Remove the covering to the printer's outer case to expose the jam. Locate the jammed paper to ensure there is not another problem causing the stall.
3.3
Pull gently on the jammed paper, taking care not to tear it. In most cases, this will remove the jam.
4.4
Press the flashing "Printer Jam" button. This will allow the rotors to turn and facilitate the release of the jam.
5.5
Turn off the printer and firmly pull on the jammed paper. Be careful not to tear it.
6.6
Remove remaining paper shreds. if a tear occurs, remove any residual paper that may hamper printing.
7.7
Refill the paper tray and try printing again. If the jam persists, repeat the process and search for more paper.
What does system error E000 mean for Canon ImageclassD861 copier?
Remove the back plate go to Main Board then go to JP1 remove the Black jumper, connect the power cord, will show message error data and press Green Button (the Big Green for actv the copy) after that the machine do a reset and will clear the error. Return the back plate and connect power again and will work back fine.
TO RESET THE COPIER (after getting an Error Code of E000):
(Canon ImageCLASS D861)
1) Press the Additional Functions button
a. It will blink green
2) Press the < # > button
a. You will see the following:
SERVICE MODE
# 1 SSSW
3) Press the < + > or < ►> button until you see the following:
SERVICE MODE
# 7 PRINTER
4) Press the < Set > button
# 7 PRINTER
# 1 SSSW
5) Press the < + > or < ►> button until you see the following:
# 7 PRINTER
# 4 PRINTER RESET
6) Pres the < Set > button
# 7 PRINTER
< YES NO >
7) Press the < – > or < ◄ > button to choose YES:
# 7 PRINTER
# 5 MLT CLEANING
8) Unplug the printer and wait for 15 seconds. Then plug it back in.
Price of canon Image Class D861...
This type of printer has been discontinued and is no longer available for general sale. You may be able to pick it up second hand, although this is not advisable as the price of the toner cartridges (the ink) is very expensive as they are probably not made any more either. It may be a better idea to go for a newer model of printer that hasn't been discontinued. I personally recommend the Samsung CLX 3175FN.
Good Luck!
John
I have an ImageCass D861
This is coming from 1 of 2 places. The first and most common is the toner cartridge itself. If you have a spare go ahead and replace it. If not you will need to get another cartridge and swap it with your current cartridge. This will correct the copy quality 9 times out of 10 on these machines. If a new cartridge does not resolve the issue then the only other cause is the fusing unit. The fusing unit is located right where the paper exits the machine. It heats up and uses heat and pressure to "fuse" the toner onto the paper. When the fuser film in the fuser starts to go bad they will start to run dirty and also "double image" where a part of the printing from the top of the page gets reprinted lighter at the middle/bottom of the page. Sometimes you may also hear a crackling sound coming from this area which can be a sign of the fuser film going bad. The fuser replacement is much more expensive to have done so let hope that the cartridge will resolve your issue.
Good Luck and Thank You for using Fixya.
Canon pc720 makes
Your scan lamp is going bad. It is the flourecent type lamp that lights up under the glass. You can try making a copy with the top cover open and watch it. You will see it flickering before the code comes up.
$75 from precisionroller.com Part#L5180 or the canon # FH7-3272-000
