Lexmark Z1300 InkJet Photo Printer • Uploaded on Feb 23, 2014
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Clean Cartridge Nozzles (Solution Center):
1. Open the Solution Center. Click Start >
Programs or All Programs > Lexmark 1300 Series. Select Solution Center.
2. From the Maintenance tab, click Clean to fix
horizontal streaks.
3. Click Print. A page prints, forcing ink
through the print cartridge nozzles to clean them.
4. Print a document again to verify that the
print quality has improved.
165 questions posted
280 Questions
231 Questions
114 Questions
115 Questions
111 Questions
