20 Most Recent
Samsung Galaxy Y Gt-s5360 - Black unlocked Smartphone Questions & Answers
Samsung galaxy gt-s5360 network unavailable
First Option:Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved SoSecend Option:Your Phone Network IC Fault So Please change Network ICAnd Network Signal Problem will Solvedif it is there isn't much you can do on this side of the network.Contact your phone company.
How to block numbers to phone
Press the green phone button, on keypad press call settings and you should see call rejection, press that and go to auto reject list and add number or tick unknown
How to repair a deadbooth android cellphone
There might be possibility of hardware faluer,if the device is not booting.
If you are able to switch ON the mobile by pressing Volume UP key + power button +Home button, it will open in Download mode.
Here you can connect your device to computer via USB cable and use the Odin Flash tool for SGY GT-S5360, and flush the ROM.
You can easly get the Odin over internet and stock ROM for SGY.
In case you have any query, revert me back.
Too many pattern attemps
1 - Press Volume + , Home, Power2 - use volume to select wipe data/factory reset3 - Yes (delete) all user4 - It will reboot5 - DoneGood Luck!
