20 Most Recent
D-Link DFL-800 Firewall Questions & Answers
How to block Facebook on both http and https
what OS you have Win XP and Win 7 go to accessories Note padright click run as administrator highlight on desk top and in the box where it says file type c\windows\system32\drivers\etc\hosts and click openthis will pop up# Additionally, comments (such as these) may be inserted on individual#line or following the machine name denoted by a '#' symbol.##for example:## 102.54.94.97 rhino.acme.com #source server# 38.25.63.10 x.acme.com # x client host# localhost name resolution is handled within DNS itself.# 127.0.0.1 localhost# ::1 localhost___________You type in the blank area__________ 127.0.0.1 facebook.com 127.0.0.1
www.facebook.comThan press file and save that should work for windows xp and 7 I’m happy to assist further over the phone at
https://www.6ya.com/expert/jaime_08785c7d726a554e
I am able to connect
The gateway at the remote end may be down. Ensure that the remote gateway runs fine. See whether the application server (80.0.75.62) has communication with remote gateway.
How to open outgoing tcp connection...... i'm facing errors
Follow these steps:
Start-> Run-> cmd
In the black box type: ipconfig [enter]
You should see some numbers like this:
192.168.*.* IP
255.255.255.0 Sub
192.168.*.* Gateway
Go to an Internet Browser and plug in your Gateway address like this:
http://192.168.1.1
or
http://192.168.0.1
Now your username and password will be like:
admin:admin
admin:1234
admin: {no password}
{nouser}:admin
{nouser}:1234
You get the drift.
Once you are in you can manipulate the firewall and port forwarding settings...
FTP problems.
There are 2 ports used for FTP. They are 20 and 21. When you initiate a connection that occurs on port 21, but data traffic is on port 20. Your firewall sees your outside FTP server trying to 'initiate' a connection on port 20 and breaks the connection to that IP address.
What you need to do is either use 'passive' ftp or open both ports 20 and 21 for ftp traffic in the firewall.
Urgent
hi,
As per your description,in your d link firewall outgoing 51215 port is not opened.go to the access-list or security policy or access rule (I am not sure about the name) tab.make a entry like
to:the sms site ip.
service:51215
action:accept.
Regards,
Mani.S
I have tried to setup the firewal to accept access for port 80
Some ISP's block port 80, the problem is not the firewall, following the procedure as described on d-link website should do it. If the problem is really the ISP, you have two choices:
Switching to a plan that allows you to use port 80.
Use port 8080, as alternate web port. The disadvantage is that acess will require http://ipadress:8080
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
