It looks like the Huawei launcher is failing to load. The launcher is basically Huawei's personal skin for your launcher. As to why it's crashing, I'm curious if you've flashed it with a custom rom or anything. Otherwise, the best thing to do is to go into settings, and reset the phone to manufacturers default.
This will erase everything on your phone, so make sure to back-up any files you want to keep, like pictures or recordings.
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
Hi, if you are using sim card to go online change the sim card and get the saving setting for your smart phone from your sim card company,if you have connecting problem with your wireless make sure that you can connect to any wireless network if you can so your wireless modul is working fine if not you have hardware issues,if you can access the network but not go to the internet from any wireless access point so you may have problem with access point preshared key or DHCP not enabled in you access point or you have restricted because mac address or ip address or network infrastructure has problem with your cellphone so contact your network administrator or network experts,if you cant connect to any access point so you have hardware problem go to a certified repair shop to fix it(may be your antenna is not attached to your wireless IC correctly or have some harder issues)kind regard
There are two types of lock.
A consumer set passcode lock. That is easy, you just do a hard reset, which deletes all the data and reloads the software as a clean install.
Or it is locked with a PUK Lock aka a SIM Lock.
https://www.fixya.com/support/r26056685-phone_asking_puk_code
You can take emergency action to avoid the data losing or reduce the data lost to the least as follows: 1) Get out your phone from the water ASAP, and remove and battery and take out the SIM card to reduce the loss or damage on the device; 2) Don't move or shake the phone frequently, so that the water will not run around your mobile phone inside; 3) Wrap the device with cloth or handkerchief for a few minutes, and then turn off your phone, and place it into a jar or a bag filled with rice for a couple of days. But if you find something important are lost,like contacts, don't worry, you can ask for help from MobiKin Doctor for Android (Windows/Mac). Step 1: No matter which brand of your Android device is, just connect your device to the computer with USB cable Step 2: Files on your Android have been categorized and displayed on the interface. Tick off these data types you want to recover back and click "Start" button to let the Android data recovery program scan your Huawei P10. Step 3: When the scan is finished, you can preview the scanned out data, find and mark the data you wish to restore and hit "Recover" button to save them on your personal computer without losing. It's very easy.Try it.Hope it could help you. A YouTube Guide for you: Read More: How to Recover Data from Water Damaged Android Phone or Tablet How to Use MobiKin Doctor for Android
If you want to unlock a device that's locked to our network, you'll need a Network Unlock Code (NUC). If you already have one, you can unlock your phone.
