20 Most Recent Samsung GT-P6200 Galaxy Tab 7.0 Plus 16GB, 3G, 3MP, 1.2GHz dual-core, 3.2 Honeycomb 7-Inch Unlocked World Tablet PC Black Questions & Answers
usually if the contacts are not saved on your device it will display that. you can follow this guide on how to save your contacts.
http://www.samsung.com/uk/support/skp/faq/1057753
and other faqs are here
http://www.samsung.com/uk/support/model/GT-P6200UWAXEU
Samsung GT-P6200... | Answered on Apr 08, 2016
hard reset by recovery options,data will be lost
Samsung GT-P6200... | Answered on Dec 22, 2014
Let's start with the most common Hard Reset methods and go from there:
Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlightsFACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release thePower key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and theCamera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc.
With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time.
When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key.
Continue holding the Volume up and Home key until the "Android system recovery" screen appears.
Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection.
Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean.
6. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS...
While the phones power is off, press and hold the Volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step).
A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key.
Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up.
Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK.
After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK.
Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen.
7. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS.
Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit.
The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press theVolume up key to boot in this mode.
Wait for the "triangle!/Android" screen to pop up. Once it does press both theVolume up and Volume down keys simultaneously. A Recovery Menu should pop up.
Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection.
After it's done make sure "reboot system now" is highlighted and then tap thePower button.
In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through.
8. Here is a hard reset for a Sharp Android Smartphone.
While the device is off, hold the Sym button (it's located on the keyboard) and thePower button simultaneously.
Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection.
Scroll down to Yes - delete all user data and then press the Power key to confirm.
Once it is done select reboot system now and press the Power key to confirm and reboot your handset.
Important Note: On some Sharp models (such as the Sharp FX Plus ADS1) if holding the Sym button and Power key simultaneously doesn't take you directly to the Android system recovery screen you might have to do one additional step. If using this hard reset key combination takes you to a screen which shows an exclamation mark within a triangle, then press the Home key (while on that exclamation mark screen) and this should take you to your Sharps Android system recovery options.
Samsung GT-P6200... | Answered on Jul 04, 2014
Call your cell provider. One time my son locked my phone by not knowing my code. they where able to unlock it. I was not happy. Think they may have had me go to the store to do it though can't remember. Hope this helps
Samsung GT-P6200... | Answered on Mar 14, 2014
after 5 tries it will ask you to try later.. but at the bottom you will see forgot pattern... click it and login to google account that you have in you android now draw new pattern
Samsung GT-P6200... | Answered on Feb 09, 2013
It appears you have set up an alarm or reminder in your clock app or calendar app. Check those apps to see the settings.
Samsung Galaxy... | Answered on Jun 29, 2019
Don't know if it will tell you try in support section.
http://www.samsung.com/uk/consumer/mobile-devices/smartphones/galaxy-s/SM-G900FZKABTU
Samsung Galaxy... | Answered on Jun 04, 2019
Google PDF Samsung GT-S7580
Samsung Galaxy... | Answered on May 31, 2019
Aside from recovering with your google account a factory reset is the only other option.
You may be able to plug the device into a computer and get the pictures / data off, but some devices do not allow this while locked.
Samsung Galaxy... | Answered on May 20, 2019
I believe you have to "root" the Android operating system to change the download directory. Android systems all use special directories or folders for most common operations. That is why all Android phones have a Download, a Music, a Camera (and/or DCIM), a Photo, and a Video directory or folder. You have to change commands in the Android operating system to point elsewhere, and to do that you need root access.
Samsung Galaxy... | Answered on May 18, 2019
You cannot do that. Both are Bluetooth masters and will not accept data from other Bluetooth masters. They will transmit to Bluetooth slave devices, such as speakers and headphones. That can receive signals from other Bluetooth devices such as mice and keyboards as input only.
The Samsung cells that I have seen and tested have internal temperature, voltage, and current sensors. If the temperature rises, the sensor can disconnect the power and the cell seems to have a short life. Letting the cell cool down will return it into operation. If the sensor fails, the phone will see it as being cold, and will stop charging it.
If the charge voltage exceeds 4.3 V, the internal circuit will stop the charge, and disconnect the cell to protect it. If the cell voltage drops below 2 V, the same circuit will disconnect and prevent the cell from dropping to a non-recoverable level, damaging the material inside.
If the current is high, the current sensor can disconnect the cell to protect it, and after a cool down the circuit reconnects. But if something actually shorts the cells contacts, the current rises too high and an internal fuse blows, protecting the cell, but rendering it useless.
Samsung GT-P6200 Galaxy Tab 7.0 Plus 16GB, 3G, 3MP, 1.2GHz dual-core, 3.2 Honeycomb 7-Inch Unlocked World Tablet PC Black Logo
Popular Tags
11 questions posted
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Galaxy Samsung
  • Galaxy Samsung
Most Popular Question
messages show phone number not contact
  • Cell Phones
