20 Most Recent Thermador SGS36GS Gas Cooktop Questions & Answers
There is no adjustment on the ts4000. The ts8000 has the ability to adjust by turning the knob while depressed, however the ts4000 does not. If you use a hose with an in-line regulator between the cylinder and the torch that would give you the ability to adjust your flame. Make sure the hose and regulator used are suitable and rated accordingly.
Thermador... | Answered on Aug 20, 2018
Switch for burner 4 is not working properly - could have a bad contact resulting in just one spark and nothing more.
Thermador... | Answered on May 03, 2017
There is usually a kit which changes the orifice for lp. Call an appliance store to seed if they stick it
Thermador... | Answered on Oct 02, 2014
This is generally due to blocked burner heads due to spills, remove it and clean it thoroughly before going any further.
Thermador... | Answered on Jun 11, 2014
The igniter is activated by a pressure switch, when you press a button or push in the knob, sounds like it has a bit of gunk in ther e stopping it from coming out again.
Thermador... | Answered on May 25, 2014
First I would try heating it up until it is red and then twist it off. If that is not an option for you then I would get a rotary tool (hobby size) with a cutoff wheel and carefully cut into it from the side about halfway through. That will get it.
Thermador... | Answered on Apr 09, 2014
In order to reach the ignitor you must remove the maintop assembly which is one unit and it can be pull up. The rest is very easy under the maintop there are the burners and ignitor so you can replace.
Here is a link so you use as a reference.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5110053&diagram_id=192367#d192367
Thermador... | Answered on Mar 31, 2014
Lowly what the potentior does is turn on the burner control system. When you turn on a normal burner you are opening a gas valve and closing a switch to generate a spark. Thus gas flow to the burner and spark. On the extra low simmer burner there is a electric solenoid between the burner head and the gas valve. this has to open as well for gas to flow. What the potentior does is signal the simmer control what level of flame you are requesting and telling the spark module to generate a spark. Once you go to the exlow setting the potentior tells the simmer control what level of heat and will cycle the flame on and off. So when the burner knob was between low and extra low, the flame would cycle on and off. You have to seperate the top section of the cooktop from the burner box to change the potentior for it sits on top of the gas valve for that burner.
Thermador... | Answered on Dec 31, 2013
Thermador SGS36GS Gas Cooktop Logo
133 questions posted
Top Thermador Cooktops Experts
Spencer Field
Spencer Field
Level 1 Expert
Eric Gundersen
Level 1 Expert
Archie Ferrarini
Archie Ferrarini
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Thermador Cooktops
  • Thermador Cooktops
Most Popular Question
frozen locknut burner thermador
  • Cooktops
