20 Most Recent
SVP DC-12D Digital Camera Questions & Answers
The card is locked
hi..There's a little plastic tab on the side of the SD card.
Slide it upwards.
try this out..
thank u..
rate me..
Lost my user manual
If you have the software dish the manual is on there in PDF format.
If not go to the makers website and download it.
Hello
NO don't buy it. It doesnt't hold a charge you go through batteries like toilet paper. Mine won't turn on anymore and I've only had it for a year.
LOST MY MANUAL
Check this link: //http://www.svp-tech.com/download.htm
Time & date reset
Very often the date/time is maintained by a very small watch type battery built into the main board - there is no opportunity to replace this.
I have a HDDV 8800 takes 2 pictures then says memory full
Hi There N2blues Thank You For Your Post
Resolution To Your Answer Is Either If You Have A Memory card Remove It And On The Side Theres A Lock Or Unlock White Seal Put It To Unlock Or Other Solution Go Settings In Your Cam And Make Sure Your Memory Hasent Been locked.
Hope This Helps You With Your Problem If So Can You Please Rate Me If You Have The Time
Thank You
FixYa
Batteries and Memory Cards
Hi There Tensnow Thank You For Your Post
Best Solution For Battery Wise NickelCadium Rechargeables Most Are Accessable With Pc. Bascially Hookin To Pc's Usb And It Charges While You Work Or Play
And Best Solution For Memory Is Either A 512Mb Or 1Gb The Reason Easy Storage And Won't Slow The Proccess Down
And Best And Cheap Solution Is
www.Ebay.com.au
Hope This Helps And Don't Forget To Rate Me :)
Thank you
FixYa
1gb crad
have you tried the formatting function of the camera?
Press the set button to open the configuration mode. Select “Format”, press the OK button and select “YES” to start formatting.
The menu is displayed again after formatting.
Svp t-608 user manual
It is better to download the manual from the official site.
So, visit svp-tech, search for your model and then click on download manual. You will get it in pdf format.
12/15/2020 2:19:12 PM •
SVP Cameras
Answered
on Dec 15, 2020
