20 Most Recent Apple Black Iphone Model A1241 8gb Questions & Answers
2answers
How do i upgrade my iphone A1241, and why is it taking for ever to go into the internet
The iPhone A1241 is a 3G model, introduced around 2008-2009, so a bit old. - you can activate it with a cellphone service provider, if it is compatible. They may try to get you to upgrade and buy a new one, so be wary. They will install a SIM card into the slot of the iPhone (it is very discreet to see) - you can connect your iPhone to a laptop with the same wire you use to charge the phone. -Make sure you have iTunes installed on you computer - Connect the end that goes into the charging block into you computer - an iPhone is a computer in its own right, so all computers need to reset the memory once in a while. I have the most recent model and do this once a month. The reset is not just an "off" and then an "on" process. To reset without losing any data or information, you must hold both the on/off button AND the "Home" button AT THE SAME TIME, for at least 10:seconds, or until you see the Apple logo appear. Wait till the iPhone is fully restarted and then try to connect to a wifi signal to access the internet. You may see that it works relatively faster to browse, using Safari to access Google. good luck !
3/11/2019 1:06:20 PM • Apple Black... • Answered on Mar 11, 2019
Need a puk unlock for a apple iphone model#/A1241
PUK only locks sim card, just get another active sim in the phone and if needed restart or restore with sim in it.
8/19/2016 3:59:54 PM • Apple Black... • Answered on Aug 19, 2016
I can on the iphone but cannot open the menu and emergency call appears even it has a sim inside..
purchase service and activate sim
6/5/2015 8:38:26 AM • Apple Black... • Answered on Jun 05, 2015
Reset all detra
Hold down your Home Button and your Lock Button at the same time for about 10 seconds or until you see the apple logo. This will restart your phone.
4/20/2015 1:30:14 PM • Apple Black... • Answered on Apr 20, 2015
How to update iphone 3 to ios 6
it is not possible to update an iPhone 3 to iOS 6! it supports only iOS 4.2 - not newer For the iPad first generation (A1219) to update is only possible with connecting the device to iTunes on a computer. - this model supports only iOS 4.2 - NO iOS 5/ 6/7/8 update-iphone-3-ios-6-gipl0ginrcpb3zqmhnz5bdpq-5-0.jpg update-iphone-3-ios-6-gipl0ginrcpb3zqmhnz5bdpq-5-2.jpg update-iphone-3-ios-6-gipl0ginrcpb3zqmhnz5bdpq-5-5.jpg
12/28/2014 3:45:38 AM • Apple Black... • Answered on Dec 28, 2014
Bluetooth canot conect
Make sure the device is discoverable and turn the bluetooth off and on on your phone to restart the process.
6/5/2014 8:51:26 AM • Apple Black... • Answered on Jun 05, 2014
Mob is hang
get software reloaded....problem will terminate
5/21/2014 2:56:16 PM • Apple Black... • Answered on May 21, 2014
There is no assistive touch on the phone - how do I get it with home button broken?
Choose setting - general - accessability. you should find the assistive touch switch there. If you're on some apps currently and can't get out because of no home button. I guess then there is no other way but to turn your phone off first then turn it back on and go to the setting I mentioned earlier
5/2/2014 6:08:06 AM • Apple Black... • Answered on May 02, 2014
Load whatsapp on iphone a1241 8gb
Go to the App Store, click search, type whatsapp, click on the install button.
4/17/2014 10:04:10 PM • Apple Black... • Answered on Apr 17, 2014
My iphon is cmpletly refreash plz give me sugstion what i can do
spell correctly
1/30/2014 9:59:36 PM • Apple Black... • Answered on Jan 30, 2014
How to upload songs to my mobile from pc
To do this you'll need to have itunes installed. You can get it here. Once installed, add your music to your iTunes (you can deselect in settings (setting -> advanced -> copy files to itunes media folder) that you want to copy the files to the iTunes folder; do this if you don't want duplicates). Connect your iPhone with your computer using the usb cable and open iTunes. Select your phone. Now you'll have the choice to either manually add music files or synchronize your entire library. Since you only have 8GB, I recommend to sync your music manually. Drag and drop the music from your iTunes library to your device (should be in the rop right corner, next to the "iTunes Store" button)
12/2/2013 11:09:59 AM • Apple Black... • Answered on Dec 02, 2013
2answers
No SIM card for iphone 3G/8GB (Model #A1241)
You need a SIM card to activate the phone - you can even get a used/deactivated SIM.
11/23/2013 6:01:05 PM • Apple Black... • Answered on Nov 23, 2013
It is not charging
Symptom 1 bad brick charger, check it with another iPhone. Symptom 2 bad sync cable check your charger with another sync cable Symptom 3 tarnished dock connector brush connector with a CLEAN used toothbrush, until all tarnish is removed, then check with a known good charger and sync cable. Good luck!
10/29/2013 11:35:50 PM • Apple Black... • Answered on Oct 29, 2013
Sending photo's from an iphone at a photo kiosk
Is the kiosk manned with people? You can attach your photo to an email, and send the email to them! Good luck
2/7/2024 6:04:13 PM • Apple Cell... • Answered on Feb 07, 2024
2answers
I forgot my apple password
To reset your apple password 1 go to settings 2 tap your name>Password & Secretary >Change Password 3 Follow the onscreen instructions to reset your password.
9/3/2023 9:56:48 AM • Apple Cell... • Answered on Sep 03, 2023
2answers
I must reset my apple ID
Hi there, you can try TunesKit iPhone Unlocker to Remove Apple ID on Apple Cell Phones. Here a step-by-step tutorial: Step 1. Connect your iPhone to your computer First, get your iphone connected to a computer. Then launch TunesKit iPhone Unlocker, and select the Unlock Apple ID option. unlock-apple-id-4vy0pwrh42ffy145mzbxq1gb-d-0.png Step 2. Setting confirmation If you have Find My iPhone enabled on your iOS device, you will need to confirm that a passcode is set and turn on two-factor authentication on your iPhone. If the Find My iPhone feature is disabled on your device, you can skip directly to the next step and tap the "Start" button to unlock your Apple ID quickly without losing data. confirm-device-status-4vy0pwrh42ffy145mzbxq1gb-d-2.png Step 3. Remove Apple ID Once confirmed, TunesKit iPhone Unlocker will start downloading the matching firmware and then remove the Apple ID from your iPhone. unlocking-apple-id-4vy0pwrh42ffy145mzbxq1gb-d-4.png
7/28/2022 6:51:57 AM • Apple Cell... • Answered on Jul 28, 2022
2answers
Download lite mega codec pack
K-lite codec pack is free and safe, and it includes almost all video codec and audio codec. K-lite codec pack download link
7/14/2022 9:25:45 AM • Apple Cell... • Answered on Jul 14, 2022
2answers
Please can you reset my apple password
There are different methods to reset iPhone password. Just follow the below steps to reset Apple password. If you haven't synced your iPhone with iTunes before or if you haven't enabled your Find My iPhone on, you can take advantage of the third method. Resetting iPhone Password in Recovery Mode is not complicated. The steps below will show you how to do that. Step 1. Disconnect all cables from your iPhone and turn it off. Step 2. Press and hold the Home button and connect your device to iTunes. If your iPhone does not turn on, please turn it on manually. Step 3. Continue holding the Home button until you see the Connect to iTunes screen. iTunes will remind you that it has detected your iPhone in recovery mode. Step 4. Click OK. The Summary tab in iTunes appears. Click "Restore iPhone" and restore your iPhone. Recovery Mode will erase all your data and passcode from your iPhone, resetting it to factory defaults. Thus, you'll have brand new iPhone without any personal data after you reset iPhone password with Recovery Mode. Therefore, please consider carefully whether you need to use this method to reset password on iPhone. If you remember your current iPhone password and you just want to change into a new password, you can finish it with ease. Go to Setting > General > Touch ID > Passcode (iOS 9/8/7) or Passcode Lock (iOS 6), then enter the current password and tap Change Passcode. Then enter the new passcode. Now, you have reset your iPhone password. For more methods, check: How to Reset Password on iPhone
4/25/2022 2:33:38 AM • Apple Cell... • Answered on Apr 25, 2022
Apple Black Iphone Model A1241 8gb Logo
30 questions posted
Popular Products
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Apple Cell Phones
  • Apple Cell Phones
Most Popular Question
no sim card iphone 3g 8gb model a1241
  • Cell Phones
