20 Most Recent
Pyle Dryver PLAD213 Car Audio Amplifier Questions & Answers
I have a plad213 what
2 4 ohm speakers wired in series is 8 ohms and then is dropped back down to 4 ohms when you bridge it.
2 4 ohm speakers wired in parallel is 2 ohms then dropped down to 1 ohm when bridged
(most amplifiers will not handle loads below 2 ohms)
hope this info helps
LIGHT RED PROTECTION
missmatched impedance, insufficient grounding or blown transistor/other internal problem within the amp.
Pyle dryver amp light protection stays on
check your subs disconnect them the try to power the amp up if it powers up the the subs have died and it could be a problem with that amp i suggest you get a better amp
Protect light will never go off
Unfortunately, it sounds very likely that you have a defective amplifier. Usually you see a protect light on an amplifier because of an internal short, supply voltage too high, voltage too low, or speaker connections of too low impedance or grounded. If your speaker wires are completely disconnected, that eliminates the most common external cause of a protect light. Also, a protect light from the voltage being too high is very unlikely without the engine running (and an alternator problem).
The "other positive cable" you're referring to is the remote input, and it won't cause a protect light no matter how it's connected. You'd need a voltmeter to do much more troubleshooting; a protect light can be caused by a very poor ground connection, or it's possible that a poor connection at the battery or fuseholder, or a defective fuse, is causing a severe voltage drop. However, based on what you've described, it seems most likely to me that your amp is defective.
Amp problem help
your problem is in instalation of car moust driver your service car end fixed the problem of conection
