20 Most Recent
Linksys VOIP VONAGE PHONE ADPTR 2-PORT PAP2 Router Questions & Answers
Connect my phone adapter
You need to register/subscribe to a VOIP provider first like Vonage and the likes. Then you need to register through your VOIP provider the phone ports of your router. ISP is different from VOIP.
The Power(Blue) LED of PAP2
A Blinking Power LED means that the firmware is corrupt. Try holding the reset button for 30 seconds and letting it go through its reboot cycle.
Please remember to rate my solution to show your appreciation.
Amardeep
For more tips visit my blog at
http://thegeektweet.wordpress.com
3rd light from top not on
Hi,I would suggest you to first trying unplugging/ switching off your device for 5 minutes. This restores and refreshes the device. Go for it
Let me know if this works, if it doesn’t then I’ll provide some other alternative solution.
Thanks
I have a Linksys PAP2-VN
HelloThe Password/user name will provides you by Verizon, try admin:admin
Here is a list of the most prominent VoIP services providers of this type but better service:
1. Vonage
2. Lingo
3. Voip.com
4. BroadVoice
5. Packet8
6. ViaTalk
7. AT&T CallVantage
Hope it helps, if so do rate the solution
Good Luck
How to lock a PAP device ....?
i want to lock a
Open a web browser on your computer and navigate to the IP address of your router. This address is typically "192.168.1.1" or something similar.
Type in your current password and press the "Enter" key or click on the ok button
Click "Administration" to access the password alteration screen.Type the new router password two times and then click on the "Save Settings" button to immediately change your router's password.
Hope this helps, thanks for using fixya.
Correct? vote wouldnt go a miss good or bad.
Looking to buy ? volp voice model:spa3102
You could buy it from :-
http://cgi.ebay.com/NEW-Linksys-SPA3102-Voice-Gateway-Router-VoIP-SPA-3102-/170540680298?pt=LH_DefaultDomain_0&hash=item27b504446a
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
How do i get internet on my computer with a
Is your computer near to the router? If so, simply use the network cable (sometimes called ethernet cable) which was supplied with your router to connect the PC.
This is a better solution than relying on wireless.
However if your computer is nowhere near the router then you will need to use wireless. Does your computer have a wireless facility? (ie a built-in wifi card?). If not it will need one. If it does have a wifi card then please provide a little more information - operating system on computer (ie Windows XP, WIndows Vista etc) and ideally some information about the computer, (ie make model etc).
Firewall block
you don't if you are sensible. Set the firewall with the correct ports instead, ask vonage for the port settings you need.
Difficulty connecting to IP address
the other way you use the router cd.
or
in run command you can type the same address.
or
Go to (run>cmd>ping 192.168.0.1)
in case if your computer is pining this address then
delete the temp files, cookies, history.
and then on the back side of your router either you have a reset button or reset hole.Take any pen or pencil put in to that hole or hold that button for 10 sec. then release it
and try again with the same address on I.E.
Hope this will resolve your issue
