20 Most Recent EliteGroup P4M800PRO-M Motherboard Questions & Answers
There is a clear cmos jumper by the cmos battery - check manual with link provided
http://download.ecs.com.tw/dlfileecs/manual/mb/eng/p4/P4M800PRO-M2%20V2.0.zip
EliteGroup... | Answered on Apr 13, 2014
no need sistamatic digram please elaborate the problem u are facing iam a chiplevel engineer can help u we can repain the computer only on 2 side there are more circuits in inner layers wher we cant repair please elaborate the difficalties you find i might be help to you
EliteGroup... | Answered on Feb 19, 2014
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=673&CategoryID=1&MenuID=16&LanID=9
Hi everything you need will be at this website above, simply download what you need and install...
EliteGroup... | Answered on Sep 07, 2012
Oh, pick me, pick me. I know. (Lol!)
1) Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
2) The Southbridge chip of the motherboard chipset, handles the USB bus, and PCI bus.
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
The Low Pin Count Bus goes from the Southbridge chip, to the Super I/O chip.
The Super I/O chip handles the Keyboard and Mouse.
http://www.ecsusa.com/ECSWebSite/Product/Product_Detail.aspx?DetailID=673&CategoryID=1&DetailName=Feature&MenuID=16&LanID=9
The motherboard chipset for the ECS P4M800 Pro-M is a
VIA P4M800 - Northbridge chip, and a
VIA VT8237R+ - Southbridge chip.
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#AMD_.2F_Intel_processors
[The Northbridge chip is under that aluminum finned Heatsink, close to the Processor.
The Southbridge chip is to the right of the white long PCI slots.
Green square circuit board, with VIA in the middle of a silvery circle ]
Does the VIA southbridge chip looked burned, or bubbled?
http://en.wikipedia.org/wiki/Super_I/O
Which one is the Super I/O chip? Don't know. I think it may be that ITE chip to the left of the VIA southbridge chip. (VT8237R+)
http://web.archive.org/web/20070929033214/http://www.esupport.com/techsupport/award/superio.htm
Does it look burned, or bubbled?
Look at the Electrolytic Capacitors on the motherboard.
(Radial Aluminum Electrolytic Capacitors, to be more specific)
Some of these are used in the motherboard voltage regulator circuit.
SOME are for regulating voltage for the I/O bus, and USB bus.
(No, not referring to the solid Polymer capacitors surrounding the Processor socket)
1) http://www.hardwaresecrets.com/article/616
2) http://www.hardwaresecrets.com/article/How-to-Identify-Japanese-Electrolytic-Capacitors/595
3) http://www.youtube.com/watch?v=YCSNWi3UHf4
4) http://www.mouser.com/Passive-Components/Capacitors/Aluminum-Electrolytic-Capacitors/Aluminum-Electrolytic-Capacitors-Leaded/_/N-75hqw/
Look for other burned SMD's on the motherboard.
Regards,
joecoolvette
EliteGroup... | Answered on Jul 20, 2012
Hi! Please go to this page, scroll down a bit, and click the "Download" tab, and then scroll to the bottom and click on "VGA" and click download (any of the buttons). I hope this is the driver you requested!
EliteGroup... | Answered on Jun 04, 2012
If it's the VGA driver you want then it's here: Drivers
I can't give a direct link to the one you need because you have to select your operating system from the drop down menus. Select Video from the first menu and then select your OS from the second one.
If you want a driver for Windows 7 there is not a specific one, then you would use the Vista version. Please be patient after clicking the link I gave you, it took a while for the web page to appear but it does work.
EliteGroup... | Answered on Feb 12, 2012
Click start control panel keyboard hardware make sure you have the right keyboard selected
or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers
click start control panel administrive tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver
this will apply to your mouse as well
if your computer came with a motherboard disc the drivers could be on it
diconnect the keyboard then reconnect it then reinstall the driver
make sure the lead has a secure seating if applicable or the usb device
or restart you computer tap the f8 key repeatedly to enter safe mode where the only things working will be your keyboard and mouse allowing you an attempt to repair your computer
hope this helps you
EliteGroup... | Answered on Feb 03, 2012
Please would you like to be more specific. What is the size of your Hdd and the RAM? What about the processor?
EliteGroup... | Answered on Sep 27, 2011
Hi, sure you can
here is the link:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=673&CategoryID=1&DetailName=Feature&MenuID=16&LanID=9
The driveres you download needs to be unziped
before installation.
Here is a free unzip program:
http://www.7-zip.org/download.html
Click on the exe file for download.
Hope this was helpfull.
EliteGroup... | Answered on Aug 12, 2011
you might find something at cnt review of this motherboard here is the manufacturer specifics
http://reviews.cnet.com/motherboards/elitegroup-p4m800pro-m-1/1707-3049_7-31856324.html#manDesc
also some threads at toms hardware
http://www.tomshardware.com/s/EliteGroup-P4M800PRO-M-Motherboard-maps/
hope it helps
EliteGroup... | Answered on Jul 26, 2011
Ol? a partir de Canad?!
You need to install drivers for the system bus - install from this link - http://www.ecsusa.com/ECSWebSite/Product/Product_Detail.aspx?DetailID=673&CategoryID=1&DetailName=Feature&MenuID=16&LanID=9
EliteGroup... | Answered on Jun 14, 2011
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer and before you touch anything be sure to wear an earth strap hope this helps
EliteGroup... | Answered on May 29, 2011
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
EliteGroup... | Answered on Apr 20, 2011
the drivers might have been corrupted by something or you might have got a virus run your antivrus program
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
EliteGroup... | Answered on Jan 07, 2011
EliteGroup P4M800PRO-M Motherboard Logo
136 questions posted
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
vga driver missing
  • Computers & Internet
