20 Most Recent
Asrock AM2NF3-VSTA (4711140874470) Motherboard Questions & Answers
Can't get lan to work
my laptop does not show me an Ip address it just connect as long as u switched your/my router is on.
9/13/2017 1:53:00 AM •
Asrock...
Answered
on Sep 13, 2017
Running windows 7 64-bit OS
the graphic card possibly not recognized cause its 64-bit OS try the window 7 ultimate.. or update the graphic card by manual..
my computer->device manager -> then right click the graphic card which has a question mark (?)
then right click and update it with your cd installer..
5/30/2016 7:40:59 AM •
Asrock...
Answered
on May 30, 2016
When pc is turned on
Test your PSU or replace it if your power supply units fan
is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or
to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including
electrical extensions,IDE,SATA
the leads from your ((motherboard to
your hard drive)) make sure they have a secure connection and are not
faulty or just replace them there probably old and faulty
make sure all leads that
are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections
and are not faulty even the electrical extensions or just replace them they could
be faulty a computer
needs its connections to continue its cycle and have an end so any faulty leads
will end up with a computer error hope this helps
4/18/2011 1:23:41 PM •
Asrock...
Answered
on Apr 18, 2011
Ide install problem
there may be some conflict in the jumper settings so just check the jumpers and try to connect it should detect the device ...
if you still persist the problem then just check the ide bus cable there may be some problem in that ...
replace the ide cable and try it ... make sure that the ide slot is working properly ...
regards
-Dileep
12/26/2008 3:32:09 PM •
Asrock...
Answered
on Dec 26, 2008
Nothing appears on the monitor
This occurs mostly due to the the RAM which might not be plugged in properly.. remove the RAM, clean the base and plug it again.. mostly this causes this no display prob
6/17/2008 3:08:38 PM •
Asrock...
Answered
on Jun 17, 2008
Power boot up problems
Check your bios for your power failure setting
it may be set to instant on of power failure
you need to set that to off
4/26/2008 7:21:44 AM •
Asrock...
Answered
on Apr 26, 2008
Dell Precision Workstation 650 series
Is the hard drive showing up in the bios? You can get an adapter to attatch it to a desktop pc to test if its working ok and get any important data off too. They only cost a few pounds off ebay.
Hope that helps?
1/6/2008 5:43:29 AM •
Asrock...
Answered
on Jan 06, 2008
Asrock h110 disable on board video using cards for mining only
real asrock mobo told ,just the intel chipset code H110the bios controls that in bios disable iGPU. no cpu told either as some have no igpu at all.like xeons, and some mobo can run both i3+ and zeons.see this search at asrocksee how your post has no real clues?https://www.asrock.com/support/index.asp?Model=h11029 mobo made based on only intel chipet.
Asrock h110 disable on board video card
double posted you?of 29mobo not one told.https://www.asrock.com/support/index.asp?Model=h110the bios page,labeled, igpu (disable /enable ) is there.some mobo allow zeon here with zero igpu.but not yoursthey make h110 ,mobo just for useless now, bitcoin mining.watch the netflix movie how the blocked mining,then save moneyalso learn what ROI is?
Asrock G31M-S No Display/not Booting
First of all, check if there are any inflated capacitors, if there is even one- ditch MBO, other capacitors will soon follow. If no inflated capacitors proceed with these diagnostic steps: 1/ disconnect all peripherials (DVD, HDD, card reader...), leave only MBO, PSU and RAM (and CPU of course); if nothing happens 2/remove CMOS battery (CR2032) for 20-30 sec with power cord disconected from computer, that will reset BIOS; 3/ take out RAM sticks, then, if you have more than one stick, try with each stick separately (it might be faulty RAM); 4/power on MBO without any RAM-if speaker is present it should give BEEP signals; 5/ try with different PSU, many power supplies are faulty even when they do give power to MBO.
If nothing of above does not help than you have faulty MBO, because CPUs are so rare to fail that in my 10 years of experience in PC service I had 3-4 fried CPU-s, and even that was because costumer tried to clean PC, removed CPU cooler and than incorrectly placed it back or didn't put thermal paste afterwards.
MY ASROCK MOTHERBOARD OUTPUT DEVICES IS NOT WORKING
3 post all the same mobo
and all 3 same reasons.
and all 3 same answers. zero
no I added one, coin cell is dead at 7 years, you are
2004 to 2018 late to the party. 14 year old battery is 2 times spec life. for sure.
This is my system, -K10N780SLIX3 wifi Mobo -Gtx
swapping out parts, try with different power supply pull the ram reseat it maybe one at time. different memory slots. change one part at a time with good working part, never assume any part is good.
