20 Most Recent ASUS P5N-E SLI Motherboard Questions & Answers
Flash your bios
ASUS P5N-E SLI... | Answered on Oct 20, 2017
Honestly, it sounds like there might be a RAM issue. Personally, I would remove all the RAM chips (assuming that you have more than 1 installed). Then Place 1 Chip in and check to see if the machine boots up. If yes, great.. 1 good chip, shut down, remove chip, try another one. If still No, shut down, remove chip, try another one. Please keep in mind that some of the older systems especially need to run in pairs, so you might have to try different combinations of 2 to see if this is the problem. Hope this helps.
ASUS P5N-E SLI... | Answered on Apr 02, 2017
You go to AVIRA dot com and download the boot tool, or go to BITDEFENDER and run an online scan, you don't put in a new HDD just because you had a virus, it sounds like you had a problem and thought it was a virus.
Read you manual, plug in the Sata drive into Sata 1.
Do you mean BIOS post, if you don't even see the BIOS post, check your monitor with another PC.
There is only one correct power switch pin, a , + and - pin, how can you switch, there is no such thing as switching.
ASUS P5N-E SLI... | Answered on Mar 11, 2013
You get this error code if there is an issue with the drivers.
Look here:
http://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/usb-ports-not-working-error-code-43/ce6662bf-cfad-4380-a274-709bf072e3d7
Here is the homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5N-E%20SLI&p=1&s=22
Please select your windows system.
You probably need to download the chipset driver.
Open the folder, and click on global for download.
Unzip the file before you install the driver.
Look also in the bios setup, for the usb settings.
Try also to download the manual.
Try also to upgrade the bios.
Hope this will help you
ASUS P5N-E SLI... | Answered on Jan 31, 2013
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be
faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty power lead can cause you problems
computers need power and data travel through every working device and to have an end to be able work properly
make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all power and data leads make sure they have secure dust free connections
cd/dvd floppy drives need to have current go through make sure these drives are working
check you CPU make sure its securely seated and has thermal grease
hope this helps
ASUS P5N-E SLI... | Answered on Jul 17, 2012
By clicking the below link you will get the driver what you needed. Click here to go to your driver link. Thanks for usig FixYa.
ASUS P5N-E SLI... | Answered on Sep 05, 2011
http://www.mercury-pc.com/downloads_list.php?productid=857
download driver here
i hope this helpful
thank you for using fixya
ASUS P5N-E SLI... | Answered on May 02, 2011
Motherboards have a "timed-wake-up" option.
You can enter BIOS SETUP, and configure the computer to wake-up at a specified time, e.g., 01:35, on specific days, e.g., "daily".
Restart your computer.
Enter BIOS SETUP
Set the computer's clock to 01:30.
Save the setting
Exit from BIOS SETUP.
Turn the computer off.
Wait 5 minutes, until the computer's clock advances from 01:30 to 01:35, and watch what happens.
ASUS P5N-E SLI... | Answered on Mar 17, 2011
Keep in mind that if your board has a different BIOS, this may not apply:
ASUS beep code
ASUS P5N-E SLI... | Answered on Mar 11, 2011
It doesn't appear to be a RAM or CPU problem. It could be the motherboard (maybe the SATA controller), or the hard drive. There are two thinkg you can try:
1 - connect the hard drive to another SATA port, and change the boot order in the BIOS to point to the new port. If it works then it's a problem of that specific port. (motherboard problem)
2 - connect the hard drive to another SATA port on another controller. If you have the hard drive connected to a red port, try a black port. If it's connected to a black port, try a red port. If it works then it's the controller. (motherboard problem)
3 - try to install the OS on another hard drive and connect just that hard drive. If it works, then it's an hard drive problem, and you can replace that.
ASUS P5N-E SLI... | Answered on Mar 04, 2011
No, it needs a video card, of any kind, with a monitor attached to power up.
ASUS P5N-E SLI... | Answered on Feb 19, 2011
Beep codes .
Navigate to this page click HERE!
ASUS P5N-E SLI... | Answered on Jan 12, 2011
There is no problem with your hardware, but your software. I do not prefer using 64 bit applications/software since they are a bit unstable. Why not use just 32 bit since it has no problems?
We don't need to upgrade if we can't use it.
hehe
ASUS P5N-E SLI... | Answered on Dec 05, 2010
Yes as long as the 9800gtx is PCI Express x16. I am assuming the p5n-e is the Asus MB. Since I couldn't find any other Manufacturer using that MB#
ASUS P5N-E SLI... | Answered on Dec 04, 2010
double check memory slots make sure they are paired correctly- try just 1 stick in the a and then b slot
ASUS P5N-E SLI... | Answered on Dec 01, 2010
Hi.
Unplug you PC.
Reset Bios by removing the baterry for 10 minutes just to make sure it resets propely.
Restart the computer. see if any image appears on screen. if it does, configure your bios date, time etc.
nunex2_2.jpgThen you are done. If that dosnt help.. Go to a technician and ask him to change the condensors arround your processor..
ASUS P5N-E SLI... | Answered on Nov 25, 2010
you can check your video card or memory card if it is placed correctly. or else, try to remove the cards and clean the pins with an eraser so that corrosion will be removed. then gently place the cards into the slots and try to press them quite hard for them to establish good contact with the boards slot. start your pc and see what happens.
ASUS P5N-E SLI... | Answered on Nov 15, 2010
ASUS P5N-E SLI Motherboard Logo
77 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
asus p5n e sli will no longer stay more
  • Computers & Internet
