20 Most Recent
PC Connection RJ45 Connector Questions & Answers
I am trying to connect the ethernet cable to a philips RJ45 wall
There are two standards for ethernet wiring. Most cables use the B standard, but many manufacturers of central wiring boxes (OnQ, LeGrand, SmartHome) have central units wired to the A standard. Wall outlets have to be wired to the same standard as the central unit, assuming there is one. You have to determine whether the other end of whatever you are wiring is wired to the A or B standard. If you are wiring both ends yourself, use the B standard. The wiring diagrams are here:
http://www.incentre.net/content/view/75/2/
Network & Telephone Cabling
Sure you can,
But.... what are you going to use it for? if to connect 1pc to another there will be no connection, as for a telephone line only have 4 lines and the RJ45 connection to PC uses 8
Com port missing?
check to see if the computer even has a serial port, most today dont have them and use USB instead. if this is the case, contact the receiver company to see if the have a usb version of the connection cable and software and download it and the manual for it. check to see if it needs a special cable as well while on the site. it might not need a special cable but it disent hurt to make sure.
Connect two pc
you are going to connect two pc in LAN?that was you mean?
I have a problem with
dear ap inpage ka ye version download karen or is article ko parhain Apko Zaroor Faida hoga.
https://infotechinurdu.blogspot.com/2017/09/how-to-download-inpage-urdu-inpage-free.html
Panamax 1000+
Can you please advise what is the panamax 1000 the only panamax I now is for headaches!
