20 Most Recent MSI K8MM3-V Motherboard Questions & Answers
0answers
QUE CAPACIDAD EN RAM TIENE BOARD N1996 MS 7181 VER 10
Maximum 2GB
4/3/2014 7:58:56 PM • MSI K8MM3-V... • Answered on Apr 03, 2014
Good day, I have an MSI board K7MM3 already you
try new video card
11/11/2013 9:02:56 AM • MSI K8MM3-V... • Answered on Nov 11, 2013
K8m400
check your videocard.
4/26/2013 3:36:50 PM • MSI K8MM3-V... • Answered on Apr 26, 2013
Ntldr is missing on amy toshiba tecra a6
To repair missing NTLDR or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
2/26/2013 7:58:30 AM • MSI K8MM3-V... • Answered on Feb 26, 2013
3answers
I need teh drivers of motherboard MS 7142
Try this link to download:
rapid4me.com/?q=msi+ms+7142+motherboard+drivers
12/3/2012 11:25:09 PM • MSI K8MM3-V... • Answered on Dec 03, 2012
I can't get on line
Then the onboard Ethernet circuit has also been fried. Go in the BIOS and disable it then install a simple PCI LAN card (that can be bought for less than $15 at every pc shop) to get a new ethernet connection.
9/4/2011 9:53:02 PM • MSI K8MM3-V... • Answered on Sep 04, 2011
2answers
WARNING!YOUR COMPUTER CASE HAS BEEN OPENING.
chak your ram its has been bad or damged
6/18/2011 11:48:22 AM • MSI K8MM3-V... • Answered on Jun 18, 2011
No sound from MSI K8MM3-V
Try reinstall drivers (if dont have download here) then find VIA AUDIO DECK in the system tray and check under the "phone jack" and under the "speaker" parameters and correct if anything wrong. Choose 6 channal and if your motherboard has self detection function of sound devices when plug it pops up and choose correct channal per jack. your logitech connectens here see how to install.
4/23/2011 10:06:40 AM • MSI K8MM3-V... • Answered on Apr 23, 2011
I have msi motherboard and
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart or During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer hope this helps
4/10/2011 7:58:09 AM • MSI K8MM3-V... • Answered on Apr 10, 2011
I have a MSI K8MM3-V
check jumper setting may be overcloking or any utility for proccessor in msi site
12/24/2010 11:45:45 PM • MSI K8MM3-V... • Answered on Dec 24, 2010
I am not getting any sound drivers from net free
Did you try the driver from the manufacture's website
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=237
10/22/2010 1:17:48 PM • MSI K8MM3-V... • Answered on Oct 22, 2010
Hola tengo un drama la placa madre estaba con un
Placa base MSI K8MM3-V (MS-7181) de VIA K8M800 int. DDR AGP8x VGA SATA RAID LAN ATX granel sc754
Ampliar Ver producto en alta resolución K8MM3 MSI-V (MS-7181) int K8M800 VIA. DDR AGP8x VGA SATA RAID LAN ATX sc754 granel.
Producto terminado. Por favor, seleccione los artículos similares en la misma categoría
Ver más productos de MSI.
Código: AA827c
Marca: MSI
N º de producto: 601-7181-020
Enlaces: El sitio del fabricante
Enviar a un amigo
Imprimir
Perro guardián
Añadir a Favoritos
Servicio de Ayuda
Refiera a un amigo
Placa base, placa base, placa madre, placa base, placa madre MSI
Le recomendamos que adquiera junto con las mercancías
Cable de datos al disco duro Ultra cable de datos al disco duro Ultra ATA/66/100/133 ATA/66/100/133 ... 32, -
HUB de alimentación de 1 x 5,25 de energía HUB de 1x 5,25 "... 42, -
Poder adaptadores de alimentación para SATA para la Reducción de disco SATA ... 34, -
Contribuir a la discusión sólo se permite a los clientes
que ya han comprado a nosotros.
Las respuestas a las preguntas más frecuentes aquí.
Descripción de la mercancía K8MM3 MSI-V (MS-7181) int K8M800 VIA. DDR AGP8x VGA SATA RAID LAN ATX granel sc754
Calidad Placa base Micro ATX formato a un precio razonable basada en el chipset K8M800 de VIA, que pueda ser equipado con lo último Athlon de 64 bits y los procesadores Sempron con socket 754a Placa base tiene dos ranuras de memoria capaz de transportar hasta 2 GB de RAM DDR tipo 400 / 333 / 266 184-pines. Por supuesto que hay dos canales con interfaz Ultra ATA 133 y dos puertos Serial ATA, un total de hasta seis dispositivos simultáneamente. S3 Graphics UniChrome integrada de gráficos con 8 a 64 MB de memoria compartida proporciona suficiente energía para aplicaciones de oficina y el hogar. Otra extensión permite una ranura AGP 8x para una tarjeta gráfica y tres PCI versión 2.3. Disco también contiene una integrada 10 / 100 Mbps tarjeta de red Ethernet, una de seis canales AC'97 tarjeta de audio, un paralelo y un puerto serie, ocho puertos USB.
Parámetros y especificaciones:
Procesador:
Socket 754 Athlon 64 / Sempron
Chipset:
De VIA K8M800
VT8237R
Memoria:
2 tomas de corriente de hasta 2 GB DDR
Apoyo a 266/333/400 MHz
Las ranuras de expansión:
1 x AGP 8x
3 x PCI
Controlador de disco:
2 x Ultra ATA 133 (máximo 4 dispositivos)
2 x Serial ATA 150 (hasta 2 dispositivos)
Tarjeta de vídeo:
S3 Graphics UniChrome 8 a 64 MB de memoria compartida
Tarjeta de sonido:
Seis canales de VIA VT1617A, 5,1
Cumple con las especificaciones AC97 v2.3
Tarjeta de red:
VíA VT6103L 10/100 PHY
Entradas y salidas:
1 x puerto paralelo
1 x Puerto serie
1 x VGA
PS 2 x / 2
1 x audio I / O (Line-in/Line-out/MIC)
4 x USB 2.0
1 x RJ-45
conectores de expansión:
4 x USB 2.0
1 x Puerto serie
1 x S / PDIF-outNapájení:
1 x 20-pines ATX
1 x 4-pin ATX 12V
Dimensiones:
244 x 215 mm Micro ATX
3/28/2010 12:35:10 PM • MSI K8MM3-V... • Answered on Mar 28, 2010
Iam not getting bass response from the headphone
maybe the connection that you in insert is wrong try to connect the pink green color or the black it will ok
3/5/2010 5:29:32 PM • MSI K8MM3-V... • Answered on Mar 05, 2010
No sound driver
DRIVERS ARE NOT AVAILABLE FOR VISTA
CHECK THE FOLLOWING LINK AND SCROLL DOWN ON THE PAGE
1/3/2010 9:51:24 AM • MSI K8MM3-V... • Answered on Jan 03, 2010
After pressing POWER button i get 2 long beeps --
Two beeps means that you need to check your RAM. Try changing the RAM module and see if it working? If you have any display card (AGP/VGA/PCI or PCI express) installed then you need to check that it is properly inserted in the slot in the motherboard. Also check for any loose connections in display card.
12/21/2009 6:13:24 PM • MSI K8MM3-V... • Answered on Dec 21, 2009
2answers
PC Cannot Boot
Common windows problem,you need to wipe your drive and reinstall your operating system
1/8/2009 9:13:17 AM • MSI K8MM3-V... • Answered on Jan 08, 2009
Beep problem
Hello niceguy_jes2,
click on this link for the ambulance like sound beep description:
http://www.bioscentral.com/beepcodes/awardbeep.htm
"High frequency beeps while running". "Check the CPU fan for proper operation. Check the case for proper air flow".
First item to check would be CPU's fan speed. To do this, enter your bios menu. Listed there is "H/W Monitor". Open it. Check the fan speed, CPU temperature & mother board temp. Chances are the CPU fan is turning too slow & it may need to be replaced. (No less than 2300RPM's). Average CPU fan's spin at 3000 plus).
Next item if CPU fan is ok. The thermal grease between the heat-sink & CPU may have dried up over time & cause the CPU to get too hot. You may need to remove the CPU & heat-sink assembly. Clean off all old thermal grease from the bottom of the heat-sink & from the CPU. If you do this, do not scratch either surface. Use house hold alcohol on a clean rag & wipe away all old thermal grease. Apply a tiny amount of new thermal grease. Re-assemble & check through bios H/W monitor, CPU temp. One or the other will stop the system beeps.
Link to MSI: http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=237
Good luck niceguy_jes2!
Post if there are troubles.
Thank you for using fixya.
Mike
1/7/2009 6:14:31 PM • MSI K8MM3-V... • Answered on Jan 07, 2009
MSI K8MM3-V Motherboard Logo
32 questions posted
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • MSI Computers & Internet
Most Popular Question
msi k8mm3 v
  • Computers & Internet
