20 Most Recent Punch ! Professional Home Design Suite for PC Questions & Answers
0answers
0answers
How to print framing detail on punch Professional home desingn
You are suggesting to download a ten years old program? I'd suggest to check out the new versions and features The best resource to get solutions with Punch software: get the e-books of Patricia Gamburgo (one of them is free) https://www.smashwords.com/books/byseries/1234
6/23/2014 12:01:40 AM • Punch !... • Answered on Jun 23, 2014
0answers
Whenever I switch to live
I had this same problem. All the information I read said to run 32bit color. I switched mine to 16 bit and the 3D view worked great.
10/4/2010 2:45:31 PM • Punch !... • Answered on Oct 04, 2010
WHAT IS COST
$10-20 at Amazon.com
8/4/2010 6:16:20 PM • Punch !... • Answered on Aug 04, 2010
I want pc suite software for laptop to connect my
You can the software here
7/11/2010 1:47:30 PM • Punch !... • Answered on Jul 11, 2010
Black screen in 3d view
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
5/30/2010 4:50:18 AM • Punch !... • Answered on May 30, 2010
Punch Software - Professional Home Design Suite
Check your video card memory. Live view uses a lot and it pays to switch it off during normal operations and just use it to check object placement every now and again.
6/4/2008 7:03:45 AM • Punch !... • Answered on Jun 04, 2008
Print problems
Print to fit page prints thumbnail size image.
trnsp.gif Answer Zoom out to make your design appear on a single screen, drag and draw a box around it, using the Select Objects Tool. Once it's all selected, go to Edit > copy, File > new, Edit > paste. Print from this new file.
Note: this may be caused by an extraneous object on an outer edge of your plan. When you zoom out, pan around your design to see if there is a stray object, which you can delete.
3/15/2008 7:48:03 PM • Punch !... • Answered on Mar 15, 2008
Printing
3/12/2008 5:04:25 PM • Punch !... • Answered on Mar 12, 2008
My software will NOT download.
The download could be broken. Do you know the speed of your internet connection, and the size of the file?
1/28/2019 11:12:15 AM • Punch Computers... • Answered on Jan 28, 2019
0answers
Punch home suite. I want to send drawings tp printer these are in PRO file need to convert to pdf. already downloaded Primo PDF
consider Foxit PDF software (free). It has a PDF printer that might work for you.
5/4/2018 7:07:10 PM • Punch Computers... • Answered on May 04, 2018
Punch ! Professional Home Design Suite for PC Logo
21 questions posted
Top Punch Computers & Internet Experts
k24674
NOEL
NOEL
Are you a Punch Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Punch Computers & Internet
Most Popular Question
whenever switch live
  • Computers & Internet
