20 Most Recent PC Chips P23G Motherboard Questions & Answers
0answers
manual
2answers
How to increase my internet speed
click on start click on run type gpedit.msc and hit enter go to networking templates on right hand side dbl click Qos packet scheduler. click on enable and change 20 to 0. You will see an increase of 10% in your internet speed. there are such 20 tweaks through which you can increase your internet speed 16 times. They are not provided free of cost.
4/5/2013 4:12:09 AM • PC Chips P23G... • Answered on Apr 05, 2013
Audio device error
As you don't say what your device error is I would suggest trying to download and install the audio drivers again. But the audio hardware is the weakest on the board and so the most likely to fail first. you can still add a soundcard if the onboard audio has failed.
2/18/2013 10:47:42 PM • PC Chips P23G... • Answered on Feb 18, 2013
Shut down during boot
Sounds like a cpu overheat situation. Check the cpu temps in the bios and compare the temps with the maximum operating temp of your particular cpu. It might need better/or/new cpu thermal paste applied to your cpu, and also check that your cpu fan is running and locked down tight (and not loose)
1/15/2013 8:54:27 PM • PC Chips P23G... • Answered on Jan 15, 2013
Bios untuk toshiba c850
Hello seach for your pc here:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jspPlease select the right model. Because flashing the bios with a wrong file will destroy the pc.Good luck
12/2/2012 10:37:54 AM • PC Chips P23G... • Answered on Dec 02, 2012
4answers
2G Memory Upgrade
I had similar problem with CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
If this is your RAM:
Corsair 1024MB Value Select PC2-4200 (533MHz) DDR2 RAM, 128Mx64non-ECC, 240-pin DIMM, Unbuffered, CL4, Lifetime warranty (VS1GB533D2) Then it is high density. You need low density to work, look for one ending with an 8, not 64.
11/22/2012 7:21:05 PM • PC Chips P23G... • Answered on Nov 22, 2012
2answers
Bagaimana cara update bios motherboard pc chips
2/17/2012 4:53:50 PM • PC Chips P23G... • Answered on Feb 17, 2012
2answers
What ram does a pcchips
Thanks for posting your question. This took me a ton of time to find. Please leave me a great rating on this answer for finding the solution.
DDR400+DDR2 533 Supports Single-channel DDR2 533/400 DIMM and Single-channel DDR400/333 DIMM. Users can use either DDR2 or DDR memory modules.
Again, please leave me a great rating on this answer so others may benefit from this solution too!
9/24/2011 8:09:21 AM • PC Chips P23G... • Answered on Sep 24, 2011
2answers
My motherboard is the PC
they are two row pins
firts row have four pins (one hole is empty NOT pins)
second row have five pins
power On/off connect to pins near to hole (empty without pins)
next to side Power switch , connect "power led"
below power on/off connect "reset"
next to side Reset switch , connect "HDD led"
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
9/19/2011 7:58:48 PM • PC Chips P23G... • Answered on Sep 19, 2011
3answers
I have bought a kingston
If its one RAM den be sure it is 2 GB if 2 RAMS den please see that have you fixed the RAM properly..Try taking out the RAM and clean the lower portion with a clean Rubber/Eraser and dne fix it back properly..
7/29/2011 7:26:10 AM • PC Chips P23G... • Answered on Jul 29, 2011
I had trouble with pins
Here is a link to two versions of the motherboard you have. Figure which version you have and download the manual for it. Use the manual for your connector configuration and locations.
http://www.pcchips.com.tw/PCCWebSite/SearchResult.aspx?q=p23g&f=Products&MenuID=104&LanID=0
4/6/2011 7:57:44 PM • PC Chips P23G... • Answered on Apr 06, 2011
Did you know what are the cheats in backyard
No real cheats per say however very usefull tips:
(1) if you have mushrooms in your back yard, simply click on the mushroom, and select 'pick' to pick your mushrooms. They can earn you shiny simply for picking them, between 3 and 10 shiny at a time. This is the easiest way to gain, save and collect shiny for free.
(2) Also, if you play with 2 accounts, you can use one to attack the other until it hits 60 percent, then end the attack, and you'll earn 12 hours of free protection for relatively little damage.
(3) spend 700 shiny on 28 days worth of protection. Use all of this protected time to bank resources and build up a strong base. You can very easily be all the way up to level 35 by the time all of your protection has been used already. This makes it very easy to build a super-powerful base and unlock loads of monsters, and build up a rich array of resources. Best of all, you'll easily earn back that Shiny with all of the various time log in bonuses. Bank your free shiny bonuses into buying protection time, and you'll be able to continuously bank resources and build up your base to stratospheric strength.
Thanks
11/28/2010 6:55:45 AM • PC Chips P23G... • Answered on Nov 28, 2010
Gosto ko ng cheats ng specialforce na free
Cheaters are losers! Just have fun and play it fair & square!
11/10/2010 4:58:45 PM • PC Chips P23G... • Answered on Nov 10, 2010
My windows xp was recently
control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
good luck
9/14/2010 8:41:01 AM • PC Chips P23G... • Answered on Sep 14, 2010
PC Chips P23G Motherboard Logo
65 questions posted
Top PC Chips Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • PC Chips Computers & Internet
Most Popular Question
bagaimana cara update bios motherboard
  • Computers & Internet
