20 Most Recent Samsung Rv-511-a01 Notebook Questions & Answers
If it is an IDE hard drive, this will be a flat ribbon cable with 40 pinouts. You will plug the cable in the matching socket closest to the CPU (there will always be a few available sockets)
If it is a SATA hard drive the cable is much slimmer with a right-angled connector. If you look really closely at the connector blocks on the motherboard they will be numbered from SATA0 to SATA3 (or higher depending on how many are there) - choose the lowest available number.
Samsung... | Answered on Aug 10, 2013
It is most likely a bad battery. Also, if you can find another charger like the one you have you could check to see if the charger itself is the problem. In my experience, the battery is the likely culprit.
Samsung... | Answered on Sep 27, 2012
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x
right click you will need to update the driver
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected in xp
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
for the double click this will be in the folder options follow previous to get to control panel items
click start control panel navigate folder options tick in the double click to open circle
hope this helps
Samsung... | Answered on Sep 16, 2012
Your message does not qualify as a question or query for a problem, try somewhere else
DO NOT MAKE THIS SITE WITH YOUR GARBAGE
Take your GARBAGE to another Side
Your message qualifies as SPAM
Samsung... | Answered 3 days ago
...****WARNING**** THIS POST IS SPAM. NEVER CALL ANY NUMBER POSTED ON THIS WEBSITE. YOUR CREDIT INFO AND COMPUTER ARE IN DANGER IF YOU DO...YOUVE BEEN WARNED. DONT BE STOOPID.......****WARNING**** THIS POST IS SPAM. NEVER CALL ANY NUMBER POSTED ON THIS WEBSITE. YOUR CREDIT INFO AND COMPUTER ARE IN DANGER IF YOU DO...YOUVE BEEN WARNED. DONT BE STOOPID....
Samsung Rv-511-a01 Notebook Logo
6 questions posted
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Computers & Internet
Most Popular Question
get connecting wires connect
  • Computers & Internet
