20 Most Recent
Lakewood 2727 Heater Questions & Answers
No heat coming from it
Let's try trouble shooting the situation, and see what clues we have:
Are there any lights lit?-- How do we know for sure, we have power into the unit?
Are there any resets?- or maybe turning the Thermostat all the way to one end of it's travel, or the other, might re-set it?
There must be some clues-- Unplug it, and start from the beginning, and listen, and observe everything for ANY CLUES!
Let us know what you find, and tell us any clues you see or hear.
Mack B.
How do I add oil to help heater warm better??
they are a sealed heater you can't add oil to get more heat, if you can must be a new type i haven't seen, but if not hot enough throw away and buy a heater that works they work on the principal that an element heats the oil and runds on an internal thermostat to control temperature of oil, your element may be starting to deteriate the same as hot water you only notice with hot water as it starts to not heat the water as much and you feel this in a shower or bath but you won't notice the same in oil heater it won't heat as it has and it may also be the thermostat, inside heater i wouldn't even bother trying to repair waste of time and money i would buy a proper working heater prefrably one that could be fixed to go better after its starts to deteriate a lttle
Recall
I had the 5101 I just sent it back last week to manufacturer,most of oil filled heaters make a noise as the oil heats up. The 5101 had a black control panel &black wheels & foot rest. Hope i was of some help. If u have more ? let me know.
[email protected]
Have a Lakewood HV9 that died.
No. If my memory is correct it has a thermal fuse in the winding that opened. It was not designed to be replaced or repaired. Your berings froze up stalling the motor. It got hot and took out the fuse. You got a lot of years of good service from it.
I need wiring diagram for a Lakewood heater
try this link.
https://images.app.goo.gl/eqouF5WZLpQbu987
There are several diagrams for lakewood heaters.
Youb can also do a search google by typing in (wiring diagram for a Lakewood heater).
