20 Most Recent Epson Stylus Sx445w Inkjet Print Scan 5760 X 1400 Dpi Print 33 P Questions & Answers
2answers
I installed a new printer: Epson Stylus SX445W.
Any number of possible reasons why the drivers didn't install properly but that's basically what seems to have happened.Try uninstalling the driver, downloading the latest version (for your operating system) from the Epson Support section of their website and then reinstalling.Remember to have the printer turned off and the usb cable disconnected until prompted to do so.Might also be worth disconnecting from the internet (for safety) and disabling any of your anti-virus or other software while you install the drivers as they can sometimes cause problems.Obviously once you're done, re-enable anything you disabled and reconnect to the internet as normal.With a little luck that should cure the problem.
7/16/2019 7:26:45 AM • Epson Stylus... • Answered on Jul 16, 2019
Why am I getting double or treble spacing on the printed lines
It could be that the disk located to the left side of the paper feed (when looking inside from front) is soiled with ink. The disk has tiny lines on it that are read by a sensor like steps so the printer counts the "steps" to work out how far the paper has progressed through the feed. If this is dirty with ink, grease or similar, it will not be read properly and result in the paper feeding further than it should. This assumes that the issue is printer related however. It could be that your source document/editor is causing the problem by not displaying what you want to print. You can identify if this is the case by printing from some other application like a web browser or similar to see if the spacing still takes place. If it does the printer is the fault... if it doesn't it's your software. Hope that helps.
3/17/2015 9:07:03 PM • Epson Stylus... • Answered on Mar 17, 2015
When I scan a document for it to be sent to my computer it arrives in about 6 sections of the original document
Go to Printers and imaging products select your region from the list below and download the manual. Usually there is a setting in the software such as create separate document from each scan.
1/25/2015 4:51:09 PM • Epson Stylus... • Answered on Jan 25, 2015
Epson user guide
You might have disconected your printer without shutting it off nor asked your computer to disconec the printer. You might have damaged your usb connection. Taking the precaution measures try another usb connection
7/27/2014 3:09:55 PM • Epson Stylus... • Answered on Jul 27, 2014
Epson troubleshooting
What you have I highly suspect is a highly clogged print head. Even if you continue to clean your print head you will use ink to do it, so you will be spending a lot of ink and trust me it wont fix the problem. I have two epsons 1400 and had the same problem and used cleaning solutions but at the end it helped but did not fix the problem. So at the I decided to use a cleaning solution that comes in cartridges specific for your printer. Its name is UNBLOCK UNCLOG CARTRIDGES, Its seller in E-bay is Sy1507. It worked. but for example it took me around three days. I printed a job and let it sit for a couple of hours until the page printed all white. After the page prints all white then you change the cartridges with ink and do a test print and if prints right, do a print job, You will be amazed at the results. Good Luck.
7/25/2014 11:38:09 PM • Epson Stylus... • Answered on Jul 25, 2014
0answers
Epson Stylus SX445W printing pictures with a red tint
Dear Kate, please run the Epson maintenance software and check your printer cartridge. i think printer head cleaning is the solution. please run 1 or 2 cleaning cycles and give a try again. if problem still there its time to go to technician. regards, nuwan.
1/10/2014 5:52:19 AM • Epson Stylus... • Answered on Jan 10, 2014
0answers
0answers
Misprinting
Be the first to answer 11/22/2013 3:05:29 AM • Epson Stylus... • Posted on Nov 22, 2013Be the first to answer
0answers
Epson sx445w
Be the first to answer 5/10/2013 7:30:16 AM • Epson Stylus... • Posted on May 10, 2013Be the first to answer
2answers
Epson lq-690II printer reflects the paper when printing
Troubleshooting Paper Reversal in Printers: *Confirm that options related to paper handling are set correctly by checking for specific buttons or switches that relate to paper handling or reversing. *Ensure that paper is loaded properly to avoid feeding problems. *Remove any dust, particles, or paper remnants from the rollers, as they can impede paper flow. *If other measures fail, reset the printer to its initial settings to resolve potential software glitches.
4/2/2024 6:40:17 PM • Epson Office... • Answered on Apr 02, 2024
Old but New in box epson pictureMate photo lab has paper jam error but never had paper in it .what can i do ?
If you take is apart you may find jammed gears or dry lubricant causing a 'paper jam', due to its age and storage.
2/29/2024 9:14:17 AM • Epson Office... • Answered on Feb 29, 2024
EPSON 15140 error 034019
Try a hard reset of the printer. Oddly, the 034019 is not an error code, I have reason to think. It is a contact number, I believe.
2/25/2024 3:05:22 AM • Epson Office... • Answered on Feb 25, 2024
6answers
Reset my Epson printer L382
Follow the steps given below to reset Epson L382 printer. Step 1: Turn the printer off. Step 2: Press and hold the reset button which is on the back of the printer using a paper clip or tip of a pen. Step 3: Turn on the printer by holding the Power & reset button and continue to hold both the buttons. Step 4: Wait for 5 seconds and a warning sheet will print. Release the reset button. Step 5: After 5 seconds, another sheet will print which will show the IP address of the printer. hold the reset button which is on the back of the printer using a paper clip or tip of a pen. WHERE IS RESET BUTON? I CANT FIND IT.
1/30/2024 1:36:34 PM • Epson Office... • Answered on Jan 30, 2024
Epson Stylus Sx445w Inkjet Print Scan 5760 X 1400 Dpi Print 33 P Logo
18 questions posted
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Epson Office Equipment & Supplies
Most Popular Question
when scan document sent computer arrives
  • Office Equipment & Supplies
