20 Most Recent
Sharp LC-26SD1E 26 in. LCD Television Questions & Answers
Only getting snow on tv
Does this aerial work with other televisions?
Has the Sharp worked on this aerial recently?
If the aerial works with other televisions, and the Sharp has worked on the aerial recently, it sounds as though the tuner stage has stopped working, though it could always be a digital decoder (if fitted).
Why does the screen shut down after 1 sec while sound continues
It sounds like bad luck to me. You cannot change any settings on a TV by connecting a computer to it. In theory you can damage any monitor by setting the screen resolution of the computer higher than the monitors maximum res. The Sharp 26" has a resolution of 1366 x 768 (1080i) so (again in theory and I have never seen it happen) if you set the output to 1920 x 1024 (HD - 1080p) it can kill the screen. Perhaps this is what has happened. You will need to take it to a Sharp service centre.
Can i switch off in
Clicking Menu, SetUp, Reset will reset the television and take it out of demonstration mode. You may have to re-program your channels & labels however, but you will get out of demonstration mode.
Colored shadows - borders on
Convergence problems are usually caused by a diode on the convergence board. These little critters have a tendency to short out and cause the convergence to do strange things.
Obviously, this is not a job for the home owner because few of you know electronics. So, call in the technician to make the troubleshooting of the circuit. The diode costs .98 dollar. The technician will cost you about 250dollar. Don't ask me to explain it.
That's the way it is today.
Hope this helps out......
