20 Most Recent
Sony Bravia KDL-46X2000 46 in. HD-Ready LCD Television Questions & Answers
How to replace screen
It is really a skilled work. You have to disassemble the set as a whole, to replace the screen. Even after replacing it, there should have some adjustments to be done. It will be best to contact any service technician, or the authorized service center for Sony. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Pull up older posts. Surf the site with patience.
Do a search by type in the brand name of your device at its search box and press "Enter".
Disassemble procedure to many popular brand TVs and others are given with illustrations.
How to replace brpken screen
Go and look on ifixit.com. There you find tutorials about how to fix almost anything. Then try to buy a new screen and look what it will cost. If you can buy one, it could cost lots and lots more than a complete new TV the same size or bigger. And then you still have to do the repair. and have an old TV.
How to replace broken screen
Don't even try this at home. Before you should think of replacing a screen, just ask what a replacement screen will cost. If you even can buy one. If you can buy a screen, it could cost up to 10 times as much as a new tv from the same size.
If you still want to replace it, please look on ifixit.com. there they have tutorials about almost every repair you can think of.
Television Schematics
Two blinks denotes an over-current protection. There must be some short circuited component/s at the main board. If you wish to get more details, surf this link.
http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related
to television and other domestic electronic equipment service help. More than
Nine and half Lakh viewers cannot be
wrong.
Sony lcd no picture
I see so many here with no sound/nopicture issues:ISSUES: 1. IF sound main fuse/s are good.2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.3. almost all these sets the troubleshooting involves
checking voltages on the main power board to narrow down theproblem.4. Be safe and if you do not know what you are doing don't open the set.Answers to issues:1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
Sony tv screen has no picture
Watch the red light and or power light when this happens, if there is a specific number of blinks and then a pause that is a error code.
Hi, I live in a flat in London with a shared
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
6 flashing lights
Similar problem with my Sony. I unplugged for 36 hours and it seemed to solve the problem.
Sony Bravia 46 XBR has the input bar stuck at the top of screen.
Unplug the TV for a while and hopefully, that should reset the circuity. If you're using the original remote control, check for the display button and press it.
I would also suggest doing a factory reset if your TV has that feature and if the TV allows you to do it after unplugging it.
I need to remove the back off a Sony Bravia KD-48X81J
The front and back pieces are like a clam shell and are compression fit with tabs into one another. You need to use something like a guitar pick or spudger to separate the pieces. Dont use metal objects due to damage that will happen to the plastic .
