20 Most Recent Toshiba REGZA 47WLG66 47 in. HD-Ready LCD Television Questions & Answers
2answers
47" Toshiba randomly shuts off and powers back on a couple minutes later.
Sounds as if your main board is defective and needs to be replaced.
3/18/2013 12:50:16 PM • Toshiba REGZA... • Answered on Mar 18, 2013
I want to program my audio reciver to my toshiba remote
REFER TO ITS MANUAL
9/12/2012 4:37:07 AM • Toshiba REGZA... • Answered on Sep 12, 2012
CANT GET SIGNAL TO GO
Please check the cable and connection..What cable did you used,it is RCA jack or HDMI cable?Check also the setting.
7/16/2011 8:51:08 AM • Toshiba REGZA... • Answered on Jul 16, 2011
I just need to know
I am not sure what you mean by a Multi-system? But I can tell you that replacement manuals are available on line for free on their website. The Regaza is a US model and the website to locate the manual is on www.us.toshiba.com. Click on Customer Service and then tv's and LCD then scroll the model numbers listed to find yours and click on it. There is troubleshooting and chat services available in that area. Hope this helps?
7/4/2011 8:36:45 AM • Toshiba REGZA... • Answered on Jul 04, 2011
I have a Toshuiba Regza 46 in screen that has a
Lines can be cause by your T-con board or by the screen itself. The only way to know is by replacing the T-con board. If they go away then it was the T-con board if they do not it's your screen that is bad. When changing the T-con board it is also a good idea to change the ribbons that connect it to the screen. You can get parts from www.interliquidparts.com
6/3/2011 11:17:58 PM • Toshiba REGZA... • Answered on Jun 03, 2011
My panel has broken when
You were advised correctly. The LCD panel is the single most expensive component in your tv. It will cost more to obtain and fit than if you replace the whole tv. You also get a new manufacturer's warranty with a new tv which you wouldn't have with a repair.
When you buy almost any flat panel tv, you're effectively buying the flat panel component at a bulk discount rate and all the other parts are thrown in for free.
9/21/2010 1:39:29 PM • Toshiba REGZA... • Answered on Sep 21, 2010
Tv won't turn on
you might want to hook it straight to the wall plus the surger may be fried even though it turns on it may of messed your tv up so i would try that if not then get back with me and i'll try to help more
6/7/2009 5:25:27 PM • Toshiba REGZA... • Answered on Jun 07, 2009
Toshiba 47WL T66
Correct, its problem of LCD Panel and will be replaced.
No alternate solution for vertical or horizontal lines in LCD Panels.
11/10/2008 3:38:03 PM • Toshiba REGZA... • Answered on Nov 10, 2008
Can I use wireless headphones with the 42HL67US
Good wireless headphones have "line in" cable with 2 RCA plugs, which must be attached to TV's "audio out connectors. If you have only "optical" or "coaxial" audio stream out, you must upgrade your "wireless" gear to accommodate those signals. Forget about "headphone" jack! It's a blast of the past!Thanks,Alex.
12/4/2022 1:02:47 PM • Toshiba REGZA... • Answered on Dec 04, 2022
3answers
My Toshiba 75u7880az LCD tv blows the 5A fuse as soon as its plugged in!
Hi, Please immediately stop using this device and send it to Toshiba for a repair or replacement. It's not normal for a tv to blow fuses like this and could be a fire hazard. Thank you.
6/29/2022 8:27:02 AM • Toshiba REGZA... • Answered on Jun 29, 2022
3answers
Only black and white image show in my Toshiba tv
I would try sing a TV converter and a digital converter and see if that fixes the problem.
4/9/2022 1:49:55 AM • Toshiba REGZA... • Answered on Apr 09, 2022
Need to unlock side panel on Toshiba regza 42AV635DB without remote
Without a remote control, you can't. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. All the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check these sites too. http://remotesearch.blogspot.com/ https://elektrotricks.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops; as well as online shops. Visit the sites by Desktop computer and type in the brand name of your device in the search box at the right column. It will help you find the remote you have to buy. Mobille view has no search
8/30/2021 2:38:33 PM • Toshiba REGZA... • Answered on Aug 30, 2021
TV will not turn on. IS not connected to a computer
Some people recommend trying to update the firmware via USB. Instructions here, http://hubpages.com/technology/How-to-Update-Toshiba-TV-Firmware. If it is a model 32C120U, there is a known manufacturers defect. This issue is cause by defective main board because the main processor is not well solder to the PCB or the e-prom memory lost the software data. Some time you can try replace the eprom memory on the main board (cost of the e-prom $15) or re-solder with a hot air gun the processor but 90% of the cases you have to change the main board, the cost is around $30 you can find it in www.myshoptvs.com these guy are super. To replace the main board is easy and takes not more than 25 minutes. This could be your board here, http://www.myshoptvs.com/marketplace/4169-toshiba-32c120u2-main-unit-461c4q51l11-431c4q51l11-vtv-l40613-m6662.html
3/19/2016 4:04:33 PM • Toshiba REGZA... • Answered on Mar 19, 2016
My tv screen is blank
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/ Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
3/10/2016 8:45:29 AM • Toshiba REGZA... • Answered on Mar 10, 2016
2answers
The words "Retrieving data" keep flashing on TV screen, even during normal programs, how do I turn this off?
Corrupted software. Contact the authorized service centre. Electro help
11/18/2015 8:12:28 PM • Toshiba REGZA... • Answered on Nov 18, 2015
How to fix vertical lines on my tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
8/27/2015 6:56:35 AM • Toshiba REGZA... • Answered on Aug 27, 2015
Toshiba REGZA 47WLG66 47 in. HD-Ready LCD Television Logo
17 questions posted
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
REGZA Toshiba
  • REGZA Toshiba
Most Popular Question
just need know
  • Televison & Video
