20 Most Recent
LG 42PC1D 42 in. Plasma Television Questions & Answers
42pc1d turns off .pop from speakers
Disconnect the Y-Sustain board (that's the one on the LEFT looking from the back) from power and try to see if the TV remains on.If nothing changes disconnect the ZSUS board from the power and try again.This should tell you if a board is causing the issue and it most likely is.For service or other questions usewww.coppelltvrepair.com/newserviceandwww.coppelltvrepair.com/diagnose
Plasma tv is turned off at powerpoint when not
Dont know about this model but alot of tvs have little solenoids that go bad that triggers the power on your set,if you know some one have them replace it with an optic coupleror replace the solenoid yourself ,not that hard really
I have perfect sound but
It can be bad sustain boards, it will require in-depth troubleshooting since you do not want to buy the wrong sustain boards or the power supply module.
Verify at least that the power supply and sustain baords do not have any bad caps with leaking/bulging tops first.
I have a LG plasma
probably the pop was a fuse blowing inside that only controls the lamp should be an easy fix but open the tv at your own risk
Is there away to connect
Ofcourse you can. Do you see a small circular port above RGB/DVI? It is the headphones jack. You can connect that to either a pair of head phones or your regular computer speakers.
My tv has stopped working i trun it on and the
Sounds like a popped fuse or worse...a blown power supply.
Check with LG about service guides for you TV if you want to take a shot at locating and replacing these parts.
Good luck and be careful.
LG Flat panel tv
Adjust Color in menu option.
Keep a sufficient distance between the product and the VCR.
Try another channel. The problem may be with the broadcast.
Are the video cables installed properly?
Activate any function to restore the brightness of the picture.
42PC1DA-UB turns of by itself
There are two possibilities; there is a hot-running component that is causing a protective circuit to trip or the power supply is failing.
There are certain parts (particularly electrolytic capacitors) which have likely already lost value and the heat inside the unit is making them fail in their task and their recovery will be poorer as they continue to fail.
The supply is normally built on a separate board
since these are often out-sourced by set manufacturers.
Unplug your set overnight to allow potentially
hazardous voltages to discharge, remove the back panel of the set so you can
see the guts.
Look for a smaller board with larger parts on
it; some cylindrical (capacitors), others block-like and relatively large
(chokes and transformers).
You should also see a relationship between the
board and the incoming AC.
Check the board for a label or if not present, a
stamped-on number.
Call the manufacturer's service center with your
TV model number and the number found on that board and inquire about
repair/replacement costs; if both are offered, they won't be that much
different.
If you must buy a new board, don't dispose of
the failed one as there are smaller companies that can repair it for less than
the mfr. and then keep it as a spare as this problem will likely arise again.
Sky remote code for 42px5d
please follow the steps below:
TV
RED + SELECT
TV
0056
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
