20 Most Recent Acer AT3705-MGW 37 in. LCD Television Questions & Answers
2answers
Whenever I switch my AT3705-MGW on, it brings up
I have the same model and same issue for the past 6 weeks. Any help would be highly appreciated.
12/21/2012 6:23:29 AM • Acer AT3705-MGW... • Answered on Dec 21, 2012
0answers
Hi I brought acer tv
Encompass parts.com
6/11/2011 6:35:53 PM • Acer AT3705-MGW... • Answered on Jun 11, 2011
I can't find ACER TV info on the web. I'm after
tenho problema de localidade numa tv led comprada na europa modelo AT2058ML que não aceita antenas do Brasil. Gostaria de saber como configurá-la, porque o menu na antena pede outros e código do Brasil, mas não sei como configurá-lo.
Sem mais,
Neori Paim
12/8/2010 11:20:20 PM • Acer AT3705-MGW... • Answered on Dec 08, 2010
Getting digatal no analog
There is not enough information to give you an answer. How do you know you are getting digital and not analog. Most LCDs are only digital even on their TV antenna connection using the ATSC tuner, so I don't really have enough information. If you are referring to the TV antenna, I assume that you have an antenna designed for this purpose.
11/30/2010 9:34:56 PM • Acer AT3705-MGW... • Answered on Nov 30, 2010
Acer at3201w when i plug it
It may have gone into safety shutdown because it sensed short circuits in the power supply or in the backlight inverter board, you will have to look inside. Please read my guide to understand what the TV needs to operate.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
8/3/2010 12:53:00 AM • Acer AT3705-MGW... • Answered on Aug 03, 2010
AT3705-MGW
Increase your signal frequency to 60hz. You may have to lower your resolution also.
2/10/2010 12:29:30 PM • Acer AT3705-MGW... • Answered on Feb 10, 2010
Tuning problem
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
10/3/2009 1:08:55 PM • Acer AT3705-MGW... • Answered on Oct 03, 2009
Acer plasma tv
Hi
Unplug the TV from the mains for an hour or more. If this power reset does not allow the TV to turn on component failure is indicated. These sets are assembled using the wave soldering process they are known for having cold solder connections. As there is no sound just make sure to check all the connections at the back, if still the issue is there then for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment as these sets have high voltages running even when switched off.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
8/8/2009 10:01:51 PM • Acer AT3705-MGW... • Answered on Aug 08, 2009
Digital tv
Hi Here is a link to an englis version of the manuals right click on the left one on this page and do a Save as, it will take some time to load as this link goes to taiwan :( file is about 4.5mb, I have checked this and it does appear ok, good luck :)
9/15/2007 3:03:52 PM • Acer AT3705-MGW... • Answered on Sep 15, 2007
Hello my Acer X110P does not light. LED light telling lamp or color wheel defect.
Help in the link, but you probably need dealer service. https://www.google.com/search?q=Acer+X110P+does+not+light ..
12/11/2022 11:31:13 PM • Acer Televison &... • Answered on Dec 11, 2022
Acer PD116Pd Projector no powerup .
Hi, Please start by switching the outlet that you use to power your projector. If you're not currently plugging the projector into an outlet but using a power strip, you can test that the power strip is still functioning by using it with other items. Thank you.
5/29/2022 9:00:02 PM • Acer Televison &... • Answered on May 29, 2022
Hello, what is the hard reset procedure on factory settings with a video projector ACER V9800, with the remote control plantes and more screen display and not OSD, thank you very much for your help
As Bob Myers mentions, the question can't be answered unless you explain which video output the camera has. The solution for a BNC CCTV camera would not be the same for a PoE IP camera. Provide that information, and we can suggest hardware that would connect your TV sets and project to the camera feed.
5/15/2020 2:21:30 AM • Acer Televison &... • Answered on May 15, 2020
Necesito los codigos para un tv Acer para un mando DVtech dv 702
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
2/12/2020 2:24:46 PM • Acer Televison &... • Answered on Feb 12, 2020
What is my remote control number for Acer brand At3235b TV?
Statistical Process Control TrainingAll Acer TV models use the universal Remote Control code NEC 18E7, which most of universal Remote Controls can use. We recommend using the search function, available on most universal remote controls, to find the compatible code for your Acer TV.
1/28/2020 8:33:23 AM • Acer Televison &... • Answered on Jan 28, 2020
How do I shut off closed caption on my Acer computer?
go into settings and find "ease of access" or "accessibility" and click on it the option to turn off closed captioning should be in there.
8/17/2019 11:57:14 PM • Acer Televison &... • Answered on Aug 17, 2019
Acer AT3705-MGW 37 in. LCD Television Logo
18 questions posted
Top Acer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Acer Televison & Video
Most Popular Question
whenever switch at3705 mgw brings up
  • Televison & Video
