20 Most Recent
HP OmniBook 6000 Notebook Questions & Answers
USB-serial controller
Hi there !
Windows Vista has many issues especially with drivers .I suggest format your hard disk and install windows 7 and your machine will work fine .
Will not boot
Check your power supply first. If it is locked up, may have to remove power (battery), then re-install. This will usually restore your factory default settings. If it's still dead and you are sure your battery isn't dead, I would dig a little deeper. Might be a fuse hidden inside the box. Remember, a computer is just a box full of parts and there isn't anything that can't be fixed. Most of them become obsolete long before they break. .... And ..... If they do break, it will most likely happen within the first 30 minutes, days, or weeks. Therefore, extended warranties, like service contracts are a waste.
I have HP laptop which was changed the bios by a
Your best bet is to use
www.unlockbiosrecovery.com and for $20 they will supply you with a HP bios master password for your laptop that will clear any set bios password and give you full access to you bios again. Did I mention that they guarantee the master password they supply to work or they refund your money. They service most laptops from Dell, HP, Compaq, Acer, Advent, Sony, Samsung, Fujitsu and more.
How to clear CMOS for
download pccmoscleaner from pccmos.com
burn the iso in a cd
now boot from this cd and you are done.
I need to find the ethernet driver for the HP omnibook 6000
get it
hereor
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?pnameOID=20053&locale=en_US&taskId=135&prodTypeId=321957&prodSeriesId=31762
select your operating system and download 3com lan driver on another computer and copy it to a usb drive or burn it onto a cd and put it on your omnibook.
Internet link
No, you need purchase PCMCIA or USB external wireless card, because Omnibook 6000 not have internal wireless card included
Wont boot up
It sounds like your windows is crashing on boot. This can be caused my many different things. First thing to try is a windows operating disk. Put the CD/DVD in your drive then try turning it on. If you still have the recovery or system disk that came with the laptop this will work as well. Hope this helps.
Boot up
You need to replace that display screen.
