20 Most Recent
Acer TravelMate 2480 Notebook Questions & Answers
When I plug in my
as you say you have not tried a different battery or power supply then may be thats what you need to do just to make sure thats not what it could be.
SHIFT KEYS NOT WORKING PROPERLY
Please try to deactivate the Fn (function) key. That will help you get rid of your problem. Press Fn key + Numlock key once and try again. You can also try pressing the Fn key once and type letters in any word processor program with the key combination everytime you press the Fn key once. E.g. open the notepad, press Fn once and after that press ) with Shift.
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
Recover acer travelmate 2480 password
Try removing the main battery and unplug the power, then hold the power on button down for 30 seconds, if this does not work, remove the cmos battery for 30 seconds to reset the bios
Acer laptops left side shift key not wrking
Reinstall your keyboard if it is software problem. If it is hardware problem you can change the keyboard or learn to use the RIGHT SHIFT key. A minor annoyance (in my opinion).
Forgot HDD password? please help?
Boot the computer in safe mode. You will be able to go in and reset your password. and once you are running you can always install your normal password. Depending on the operationg system usually F10 or F2 or on some the DEL key will get you into the safe mode.. Good Luck easy do once you are in safe mode....
How to reboot
http://www.youtube.com/channel/UCzuTqWR4qTpQkf48296H_gg?feature=mhee
Upload/Download Speed
It is quite simple... Check any of these sites below...
Visit www.speedtest.net and you will see your results...
http://www.speakeasy.net/speedtest/
http://www.bandwidthplace.com/
http://www.my-speedtest.com/
Forgot hdd password
You can use the install disk to recover password,Just boot from the install disk and follow the options
