20 Most Recent Acer Aspire 5102WLMi Notebook Questions & Answers
I have a problem with
6/17/2017 6:33:33 AM • Acer Aspire... • Answered on Jun 17, 2017
Tudo comecou por aparecer o
If your feel good information about this then click. July 2017 Printable Calendar July 2017 Printable Calendar PDF Word Excel
6/7/2017 7:12:14 AM • Acer Aspire... • Answered on Jun 07, 2017
Connecting Sony Vaio to Samsung TV
Hello, The problem is the cable. Those converter cables rarely work. they can't translate the scan rates properly. You need a converter box for the video signal, and get a cable to plug into the headphone jack on the laptop to send sound to the audio input on the TV. Here's a link to an example of the type of box you need to get the video working. Hope this helps! Joe
4/9/2017 5:22:22 AM • Acer Aspire... • Answered on Apr 09, 2017
5102 camera drivers
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark ? right click to reinstall drivers or update driver xp. Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer If you still have no webcam installed Run the "Add a device"application, accessed by clicking on the "Start" button, opening the "Control Panel," and then double-clicking on "Add a device." The "Add a device" window will open and Windows will search for devices connected to your system but not installed. Click on the webcam name that shows in the search box and then click "Next." Choose whether you want Windows to search for the webcam device driver using Windows Update over the Internet, or if you'd prefer to have the device manager search for the driver using a disc supplied by your laptop manufacturer. Most drivers can be found on the system recovery disc included with your laptop, if you choose to add the driver from the provided disc. Place a check in the box next to your choice and then click "Next" to continue. Wait while Windows searches from the driver using Windows Update, if this was your choice. An active Internet connection is required for Windows to successfully do this. Allow the computer to install the driver and then reboot the system for the webcam to become recognized by the system. Otherwise, you can use the system recovery disc or a driver downloaded directly from your laptop manufacturer to install the driver without using the Windows Update search feature. Open the CD/DVD-ROM drive and insert the system recovery disc, or place the driver downloaded from the manufacturer in an easily accessed file directory on your PC, such as on the desktop, or in your "My Documents" folder. Choose the option "Install the software automatically (Recommended)" in the "Add a device" application, and press "Next" to begin searching for your webcam driver. The hardware wizard will search the system recovery disc and install the driver automatically. Press "Finish" to close the wizard and then reboot the computer to allow recognition of the webcam. Choose the option "Install the software manually" in order to browse to the driver location where you saved the driver and install it from there. Use the opened file manager and locate the driver. Click the "Next" button to install the driver, then reboot the computer to add webcam functionality.
6/27/2013 10:28:18 PM • Acer Aspire... • Answered on Jun 27, 2013
I cant unlock my mouse sensor..
If you can't unlock your mouse sensor then follow these instructions down below:To make your mouse MOVE first you must1.Put your mouse usb in your laptop in the usb holders2.After you done, something should pop up a few seconds later near the bottom right hand side, saying usb mouse connected. Try moving your mouse now.if doesn't work:go in the control panel ( you can find that in your window by pressing the window button on your key bored)3.Then there should be a topic named " Hardware and sound" click the first topic called " view devices and printers" 4. After you clicked that there should be on the top on the page "Devices" and the bottom should be printers and faxes.5 then you can double click the device to look if right one. DONE!I hoped this worked! ^-^
9/29/2012 5:00:04 AM • Acer Aspire... • Answered on Sep 29, 2012
Screen is blank lights come on
Hook a external monitor to the video output usually on the back. If picture okay! the inverter board below the screen is defective, or the backlight behind the display has failed. But if both have the same symptom it is the Video Graphics Card that is the issue, normally built into the motherboard.
4/5/2012 10:44:41 PM • Acer Aspire... • Answered on Apr 05, 2012
Usb,webcam ,blouetooth dont work.
Try installing these latest drivers.Download the device drivers from the Acer WEB site. Makesure you select the model of your laptop the drivers you that require thatmatches the Windows version that is installed on your laptop. Use this link toget to the Acer support: - http://www.acersupport.com/drivers_download.aspx
3/29/2012 9:09:58 AM • Acer Aspire... • Answered on Mar 29, 2012
3answers
Acer Aspire 5315 Slide Latch Broken
You maybe able to get your parts from this WEB site, click on this link :-
Acer parts
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=2839
11/21/2011 8:56:57 PM • Acer Aspire... • Answered on Nov 21, 2011
I'm trying to connect my
You might need to replace the cables as the cable you are using has some disconnected points. The pins of a vga cable represents different color signals, if there is a disconnect, the pictures will not display with a complete video 256 colors.
Hope this helps.
9/4/2011 2:02:20 AM • Acer Aspire... • Answered on Sep 04, 2011
Does Acer Aspire 5102 WLMI
Yes, on the top of the screen.
9/1/2011 7:26:55 PM • Acer Aspire... • Answered on Sep 01, 2011
I cannot restore to the
Try the Ultimate Boot CD (UBCD).
See a pretty nice description here:
http://www.barrywheeler.ca/acer-aspire-restore-failed-reason-0xa000000e/
8/9/2011 11:55:23 PM • Acer Aspire... • Answered on Aug 09, 2011
I cant enter boot menu
Many Notebooks show what to press to enter the boot menu in the bottom of the screen just before the boot with a logo. Or you can try F8 or F12.
3/7/2011 6:42:47 AM • Acer Aspire... • Answered on Mar 07, 2011
I have tried to restore
This is a message that is given with a blue screen? If so then it is a Common error message for Missing NTLDR. Reinstall OS again.
What version of Windows and how far into the Restore are you getting to when you get this issue?
Also, it could be an issue with the restore image/files that you are using that is causing the problem.
3/5/2011 8:30:15 AM • Acer Aspire... • Answered on Mar 05, 2011
2answers
Acer Latch is broken
On most notebooks, there is a VERY small return spring (smaller than a spring from a ball point pen) on the latch that tends to break.
1/20/2011 2:02:06 PM • Acer Aspire... • Answered on Jan 20, 2011
2answers
My Acer Slide Latch is broken on my 5315-2698?
acer computer company is run by chimpanzees
9/16/2010 5:18:56 PM • Acer Aspire... • Answered on Sep 16, 2010
ATI Graphic driver to be installed
Hi, try this link for your drivers:
http://support.acer-euro.com/drivers/downloads.html
8/14/2010 7:04:31 AM • Acer Aspire... • Answered on Aug 14, 2010
I have a acer aspire
Here is the link for the Aspire 5100 Series Drivers. Make sure you choose the correct Operating System. Your webcam driver is listed as "Camera".
http://support.acer.com/drivers_download.aspx
If downloading the driver and installing it doesn't solve your issue, please don't be hasty and trash my rating percentage with an "unhelpful" check mark. There are other reasons why a webcam might not work.
You can also go into the "Device Manager" and see if there's a webcam listed in the hardware list showing no driver or a disabled one. If so, you can double click on the webcam device listing and try to update the driver by asking Windows to do it automatically.
Good Luck
7/31/2010 5:05:39 AM • Acer Aspire... • Answered on Jul 31, 2010
Hard Drive in Acer Aspire 5102WLMi
This takes a standard 2.5" sata drive.
They are available anywhere. Here are some on Amazon
http://www.amazon.co.uk/Western-Digital-Scorpio-250gb-Internal/dp/B001IKRKO0/ref=sr_1_4?ie=UTF8&s=electronics&qid=1278958635&sr=1-4
7/13/2010 7:24:07 PM • Acer Aspire... • Answered on Jul 13, 2010
Acer aspire one error in oxf0000005 / NTLDR is missing
That is a windows error. You can try booting off the original installation CD and choose option for fix current installation, but chances are 50.50 if it will work or not. NTLDR is the bootmanager for Windows NT based systems (Windows NT, 2000, XP, etc). Critical system file, typically protected against altering.
The error code you gave is usually associated with windows having issues seeing / using a SATA drive. You will likely have to find the driver for our particular SATA controller, and load it when prompted as you startup off the recovery disk.
6/22/2010 6:51:19 AM • Acer Aspire... • Answered on Jun 22, 2010
Where can i get Atheros AR5005G Wireless Network
on line amozon .com
5/1/2010 4:43:12 AM • Acer Aspire... • Answered on May 01, 2010
Acer Aspire 5102WLMi Notebook Logo
Popular Tags
75 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
acer aspire 5102 wlmi
  • Computers & Internet
