20 Most Recent
HP Compaq Evo Notebook N600c Questions & Answers
What does configure drivelock passwords mean?
Drivelock is a security feature that allows you to password protect a harddrive. The big feature here is the password is actually on the harddrive itself and if the drive is moved to a different system you will need the password to unlock it there too. It should be noted that password recovery for this is not an easy task. So don't lose the password :-)
Non- system disk or disk error
This means it cannot read the HDD in the machine. Have you left a disk in the CD/DVD slot or a usb drive in one of the usb ports?
You may have to insert your operating system disk in the CD/DVD drive and do a repair installation.
I have compaq laptop,
lines color ? if these lines are in color red green or blue you must be change the panel screen couse yuo have brocked pixels
Removing keyboard fron acer aspire one 722
Easy in the botoom of the lap have 4 screws with mark keyb draw a key remove these screews and then go to front of the lap and pull up the keywoard thats all but some times it batary comes under the memory compariment chek it
My youtube music and video is skipping
Check heat of system. Running too hot, it will skip. Check video card driver. Make sure it is the correct one.
If none of the above, reload your operating system.
Delete my search history COMPAQ Evo N600c laptop
If you are using internet explorer go to tools-->internet options----->general
On this page Look for "History" and make "0" (zero) Days to keep pages in memory; also click "clear history". All the search history will be erased.
Always remember to click ----clear history--- before you exit internet explorer.
Power-on password bypass
You'll need to get under the keyboard or open some of the available openings on the bottom of the laptop.
What you're looking for is a battery. This is known as the CMOS battery. Once removed, power on the computer.
If it doesn't prompt you for the password, then you have successfully erased the memory.
Hope this helps :)
The 261380-001 HD for my
As far as I am aware you can use a 640Gb drive if you can get one but that is a little too large!
120Gb should be fine.
I WANT NEW MOTHER
Lots of people would like a new mother but unfortunately they don't get one.
I have brought in my notebook to a computer repair
There is a lamp for the screen that may have gone bad, I really dislike it when you fix one thing then another one happens so I understand your frustration. You will have to bring it back and have this tested again if you can go to another shop in your area to have this done because it can be complicated to do. John
