20 Most Recent
Konica Minolta 4047-601 Model IU310C Magenta Laser Toner Imaging Unit, For use with BizHub C350 Printer, 50000 Page at 5% Coverage Print Yield, Magenta Print Color, New Genuine Original OEM Brand, UPC 708562451468 4047 601 4047601 40476 IU310C IU3 10C IU3-10C Questions & Answers
I have a konica minolta c8000 with error code c3106, what does it mean?
Open the mid section of the copier and pull out main section. Then re-install. The code mean the the fuser (The large device on the left hand side that melts or fuses the toner to the paper is not connecting properly to the electrical connections in the back where it plugs into. Could be that the connector is broken because some slammed the mid section to hard. Or that you need to give the section a better/some what harder push when you close it. Might want to remove the FUSER unit and put a flashlight to the back make sure the connector is ok and check the connector on the fuser itself!
What is error c2557
What is the model number? Ball park! replace the black developer unit and black drum
