20 Most Recent
Canon New Usa Imageclass D420 Laser Multifunction Printer Questions & Answers
My canon copier D420 had a paper jam. can't get the copier to work now.
Try checking the paper path, there might be a broken or loose gear in there, a bent wire or stuck debris. If you done this and all seems ok but the error message keeps flashing, try to do a hard reset. That usually clears off error messages. If nothing happens, you might need to call a technician.
I want to contact to canon xerox service centre kolkata
http://www.xerox.com/about-xerox/contact-us/enin.html
Contact Us - Xerox
Find a local Office Products dealer in your area: Kolkotta Office Xerox India Limited 37, Shakespeare Sarani, 1st Floor, Kolkata - 700 071. Sales: 033 - 44004875 ...
- Copiers like the Xerox personal copiers offer functionality that takes into consideration ... 8/1, Lalbazar Street, Room No.1 D ,1st Floor, Kolkata - 700 001, India.
http://www.copier.in/photocopiers/personal-copiers.html
Canon ir 1024 iF shows E808 code error. How can it be fixed?
1) The error E808 occurs when one of the connectors in the fixing assembly is not properly plugged in when the unit is on.
2) This might have occurred while replacing the fixing assembly or performing a troubleshooting attempt on the machine.
3) You can find the connector above the fixing assembly at the right corner, behind the cover on the machine's side.
4) To clear the E808 error, unplug the machine from the power supply for at least 10 minutes. The error will appear again if the thermistors are in bad condition.
5)The fixing film assembly should be replaced in such case.
For more printer related assistance get in touch with our experts by just giving a call @ 1-866-293-9220.
Ir 2204error code e002-0000
The fixing film unit is faulty (i.e., the main thermistor TH1 has poor contact, or the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty. Caution To clear the error, execute the following in service mode: COPIER>FUNCTION>FCLEAR>ERR.
