20 Most Recent
Canon I-Sensys Mf4410 All-In-One Laser Printer Print, Copy And Scan Questions & Answers
Error problem
http://forum.testcopy.net/threads/how-to-fix-errors-based-on-error-code-table-of-canon-lbp-3100-3108-3010-3150.693/
How to solve canon mf 4412 error e202-0002
E202-0002
Contact Sensor HP error, Failure in return
When the same error repeatedly occurs after several times of turning the power OFF/ON, execute the following remedies.
(1) Check the connection of Flat Cable between Main Controller Board (J5) and Contact Sensor.
(2) Replace the Flat Cable between Main Controller Board (J5) and Contact Sensor.
(3) Replace the Contact Sensor.
(4) Replace the Main Controller Board.
E000-0000
the error E000 is a fuser error, the area of the machine that heats and presses the toner into the paper. It will need professional service.
Code error e100-0001 canon 4410
e100's on canon designate laser failure. there is a mechanical laser shutter that is opened when the front doors are closed. if you look at the door actuators on the inside tops of the door you will see they intersect with the actuators on the machine, make sure everything looks good in that area and the doors close properly. if the laser shutter is not actuated open the bd mirror will not receive the laser light resulting in an error state.The laser shutter actuators are located behind the toner hopper.
No destinations are set.
I had the same problem. It turned out my printer was set to print on the "Canon Fax" printer rather than the regular Canon printer. So I changed the printer on the print box screen and was able to print as usual.
Paper jam canon
Hi Jonatas Bila, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
