20 Most Recent Sony VAIO R505JL Notebook Questions & Answers
Hp altec Lansing laptop won't turn on
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
11/1/2019 11:23:08 AM • Sony VAIO R505JL... • Answered on Nov 01, 2019
Where do I locate a start up disk for my 2010
You need to create it its called a boot disk
8/19/2013 9:24:06 PM • Sony VAIO R505JL... • Answered on Aug 19, 2013
I NEED SERVICE AND REFERENCE
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=3860153&
You find any avaible manual at this site.
If this information was helpful, Please rate it high. thanks
4/24/2011 11:51:24 AM • Sony VAIO R505JL... • Answered on Apr 24, 2011
[email protected]
hi!
search web for software "tuneUp utilities 2011" download and install. run program and follow steps indicated. choose programs u wanna keep or not. u can also upgrade RAM to 640MB! total. not all 512MB rams working with this laptop but try (by the way it has 128MB fixed on board). u will be very surprised how fast this machine is with 640MB even for todays requirements it is very usefull laptop then (better say notebook :))
2/20/2011 11:26:44 PM • Sony VAIO R505JL... • Answered on Feb 20, 2011
I have a hp altec
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed-air.
Give your computer a "blow-job", shooting air into every vent that you can find, in order to remove all the dust.
A layer of dust is good insulation, thus causing your computer to heat-up, and self-protect by shutting down when "too-hot".
Also, check that the fan(s) are running -- too much dust can SEIZE the bearings on the fan, preventing it from spinning.
Don't be afraid to take the computer to a certified technician, for proper cleaning, if your attempt does not produce good results.
9/4/2010 12:23:40 AM • Sony VAIO R505JL... • Answered on Sep 04, 2010
Blank screen
hi
-remove battery pack(if you can romove memory ram aswell) and wait 10 mins
-now start charging laptop without battery pack for 2 mins
-unplUg the power AND press and hold the power button for 45 seconds
-REPLUG THE POWER CABLE BUT DONT PUT THE BATTERY PACK YET
NOW OPEN THE LID WIDER YOU CAN PRESS POWER BUTTON YOU WILL SEE YOUR SYSTEM WILL START ONCE YOUR SYSTEM BE READY SHUT IT DOWN PUT THE BATTERY PACK BACK AND CONTUNUE TO USE YOUR LAPTOP
vote me if you find your solution
7/7/2010 4:18:48 PM • Sony VAIO R505JL... • Answered on Jul 07, 2010
Hp lansing wont turn on.
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
4/6/2010 12:03:44 PM • Sony VAIO R505JL... • Answered on Apr 06, 2010
2answers
The hp altec lansing laptop wont turn on
my hp altec lansing laptop doesn't opwer on, the button lights up for 1 second and then shuts down,nothing happens to the screen, it stays blank
10/29/2009 12:40:21 PM • Sony VAIO R505JL... • Answered on Oct 29, 2009
HP altec Lansing Black screen
Try to boot in Safe Mode, If you are able to move, try to Uninstall Video driver and software. Also find this adapter in Registry and delete values very carefully, better you backup your registry.
If you are unable, a fresh copy of windows will resolve this issue.
Best of Luck,
Regards;
Hassan
7/27/2009 7:50:42 AM • Sony VAIO R505JL... • Answered on Jul 27, 2009
Dell latitude won't start
It is possible that the motheboard has gone bad.  The power brick could also have developed a short in the cable.  I would first see if you could use a different porwe cable and try that.  If that doesn't work, then i would suggest changing the motherboard if possible.
2/4/2009 4:37:57 AM • Sony VAIO R505JL... • Answered on Feb 04, 2009
Sony Viro Laptop/ No Power and no boot up
When it comes to powering up a system, one of two things could prevent a successful boot.
1. The power supply may be bad
2. The motherboard could have just stopped working.
I have run into problems similar to this with a couple of my desktops.  My desktop had a burned out board and while diagnosing I found this out.  I eliminated the Power supply by trying it in a different computer and it booted over.  Now I know with a laptop it is much more difficult to use this part swapping approach.  To me your best course of action would be to have it sent to the manufacturer if it is still under warrenty or have a technician examine it and see what the true problem is.
2/4/2009 4:35:36 AM • Sony VAIO R505JL... • Answered on Feb 04, 2009
3answers
Laptop wont power up
Sounds like the power pin is loose. I fixed one on my Z505 Sony and on my S6210 Fujitsu. The part is only 5 bucks but the labor at most shops is over 200 bucks. OUCH!
I finally figured out that tugging and pulling on the cable was what caused the pin to fail. Got a JerkStopper and haven't had a problem since I installed it.
7/12/2008 4:49:56 PM • Sony VAIO R505JL... • Answered on Jul 12, 2008
Sony vaio r505jl docking station
I googled this and found that both the notebook itself and the docking station have ethernet connections, the docking station ethernet connection seems to be between the usb and monitor connection, The notebook itself has a ethernet connection on the right side of the notebook near the back under a rubber cover. Let me know if that was correct or not.
2/29/2008 6:05:11 PM • Sony VAIO R505JL... • Answered on Feb 29, 2008
3answers
Typing in a electronic medical record online. the
If you only erased it, you can simply use the keyboard shortcut CTRL+Z, if the deletion was permanent, there is nothing you can do.
12/22/2022 9:08:06 AM • Sony VAIO... • Answered on Dec 22, 2022
5answers
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop. Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185) This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information. Causes of Error Code 0xc0000185:- 1. Suffer a cable attachment joining to your system and the hard drive. 2. Defective or missing boot files. 3. The disk drive gets damaged. 4. Wrong disk drive. Solutions of Error Code 0xc0000185:- 1: Do sure that Wire is Correctly Connected [Only for PC] 2: Automated Repair 3: Check Hard Disk for Errors 4: Repair your System to Fix Error 0xc0000185 Full Solution - Error Code 0xc0000185 wgnanor-undefined-undefined-0_3.jpg
9/14/2022 11:53:07 AM • Sony VAIO... • Answered on Sep 14, 2022
Nao consigo instalar o drive de controle de massa no meu Sony Vaio PCG-792L. Como devo fazer
www.driverguide.com use the 2 drivers free install per day freature. it will help you for sure
1/23/2019 7:29:29 PM • Sony VAIO... • Answered on Jan 23, 2019
Sony VAIO R505JL Notebook Logo
22 questions posted
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VAIO Sony
  • VAIO Sony
Most Popular Question
blank screen
  • Computers & Internet
