20 Most Recent
HP Pavilion dv2214us Notebook Questions & Answers
I just purchased a Hp
did you go into the bios and change the boot order to boot to the cd rom first? Then it should boot to the disc. Otherwise you may want to use any xp/vista disc do the install dont insert a cd key then once windows boots up then put the disc in and try a recovery.
Thanks,
Lee
My laptop dv2214us come with vista but whn i
well first check what is the mother board model used in the laptop and then log on to the web site of that particular company and you can find key words like downloads, support, driver software's so by this way you can get the required drivers for the motherboard you are using.
good luck.
My laptop(HP Pavilion dv2214us) is turnnig-on and
You need to attach the monitor and turn it on before you boot up the laptop. This will automatically switch the video data to the external monitor. If you don't get a normal Windows image then you could have a faulty video card or faulty memory.
In a laptop the video card uses part of the main RAM (memory), try re-seating the RAM module/s and see if this corrects the problem.
If not you could have faulty RAM module/s, take them to your friendly computer repair shop and get them to test them for you. If these are OK then you definitely have a faulty video chip problem. This is part of the motherboard and the fix is a replacement motherboard.
Replacing the motherboard may not be a cost effective solution, but it depends upon the age of the laptop and the costs of repair.
If you decide to get a new laptop, you can salvage the hard drive from this laptop and insert it into an USB hard drive adapter case and use it as an external USB hard drive.
My HP dv2214us cannot turn on
INSERT UR OS DISK THEN BOOT IT THEN SELECT RECOVERY CONSOLE BY PRESSINGG THE R KEY
THEN TYPE FIXMBR THEN RESTART UR LAP
PLEASE WOTE FOR ME
My laptop is not turnnig-on!
Try removing the battery and running from the AC power supply only. If this works, your battery probably can no longer hold a charge and the battery will need to be replaced.
Removing the battery allows the power supply to power your laptop rather than trying to charge a dead battery
Laptop hp DV2214 model
There appear to be three models of this machine -- if you can determine which one you have this link should leave you two clicks from the XP drivers for your machine.
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=DV2214&submit.x=14&submit.y=9
Removing virtual drive
It depends what program you used to add it in the first place. Open the software and look for settings, or just uninstall it.
What causes a red screen when starting up?
no pc told, Pavilion means zerothat name is is used on desktops and laptops for agesthe HP has diagnostics so run those. HP.com tells how.not told desktop or laptops. just 1 word."Screen"first Pavilion was 1995
What does a HP laptop notebook with model number A6Y530A look like
learn to google mate.
this is no secret,gee millions sold.
A6Y530A
the partsurfer shows true model, and fails
this is the only post here ever asking for reverse code lookups
on models fake, and is not easy in vast cases
I guess you have no such PC, (look like)
so why ask this>? what prompted this quest>? not told
why not ask seller for photos of it if this is a pre sales question , is it>?
google and bing and HP all show that model # is BOGUS
so go back to your sell and ask the we can not guess PCs ever.
HP product ID# is best on the service tag for SURE.
where did you see this number, not told.
or that number is some 20+ year old COMPAQ PC ,lost in the sands of time, and no google hits.
you posted to HP forum, (not real) Hp.com is real
Hp pavilion g series manual
what does not working mean (KBD) dead, or 1 key bad or row. what?
symptoms matter most, for sure in a LAPTOP IS IT
the word Pavilion is on laptops and desktop, dig?
G mean zero , the service tag does not just say "G" sorry.
easy peasy lemon squeezy
HP.com
complex URL no?
go there
tell them your model # or better the service tag code ! .
then magically HP puts you on YOUR service support page
and all manuals and all driver before your eyes. amazing no?
NO told at all
or of a laptop or desktop or what./?
you posted ANON so I can't just read other posts by you to learn what PC this is , no I can not.
there are over 100 PC called G series, and vast years.
some PCs by them G1 to 7 are generations, like
HP Pavilion g6-1029tx Notebook.
if you can find the service tag the product ID # is what matters most
this code includes (real model, version , options and country sold)
see this, older PCs by them had this.
see that , all matters but do not post SN/ or service codes in public.
mine: procuct code (nnnnnnABA#)
https://www.pcdied.com/TAG-jive/tag-elite8540w.JPG
I will guess it is 17" laptop, here is the mess just that 1 sized
once you see this you know that G series means not MUCH>
https://search.brave.com/images?q=hp+G+series++pavilion++17%22+G&source=web
The airplane mode button is stuck on orange although my computer say's airplane mode off
old PCs do that, for many reasons. but no PC told at all just HP.
40 years of PCs ,10000 + models nobody can guess ever.
but I do have the answer, in pure generic form.
did you buy the PC like that used and bad Wifi. ?
- the wifi card is missing, as was super common 10+ years ago.
- someone put in the wrong card, not from HP list
- HP blacklists (bios blocks) none HP cards (wifi)
- the card needs a driver to work if not it is dead or 1/2 dead.
- the PC needs 1 more driver to make the wifi buttons all work , all buttons related, if not they are dead or act odd.
- The OS is infected, no OS told at all, not one clue nor if upgraded the OS, and not vast drivers are wrong or missing, (classic)
Im sure this this is not the free w10 upgrade, if it was that too kills drivers dead, for sure HP told you this unstated PC will not run W10 and has zero support from HP, on w10 AS YOUR SUPPORT PAGE WILL DISCLOSE TO YOU AT HP.COM
