20 Most Recent ASUS A9RP Notebook Questions & Answers
HI, ive been having a
Bios is not operating properly. Either it is corrupted or you have a bad peripheral causing issues. Disconnect all you can, (hard drive, optical disk, etc) and then see if it still freezes on boot up. If you have 2 memory sticks disconnect one and try again till you check out both chips. If all disconnects do not change anything then my original comment re bad bios stands.
4/8/2017 2:52:13 PM • ASUS A9RP... • Answered on Apr 08, 2017
0answers
0answers
Service manual
Be the first to answer 12/14/2013 12:43:22 PM • ASUS A9RP... • Posted on Dec 14, 2013Be the first to answer
0answers
Service manual
Be the first to answer 12/10/2013 8:31:01 PM • ASUS A9RP... • Posted on Dec 10, 2013Be the first to answer
0answers
Repair manual
Be the first to answer 8/22/2013 6:53:36 PM • ASUS A9RP... • Posted on Aug 22, 2013Be the first to answer
2answers
I have updated the BIOS
I have done the same update to version 230 ASUS A9RP and bricked the Notebook. Nothing worked not even the power key or the battery charging. My conclusion was that the flash is also used before powering up to load a program into the devices that read keys or charge batteries. I HAVE SOLVED the problem writing bios 280, by taking out the chip 39vf040 4MBit Flash and rewrite it in writer I have constructed for it. Chip can be taken out with a hot air device , that exists in the GSM repair shops also. A socket (~0.5 Euro) can be places in the position of the chip. If you need help I offer my assistance to guide you or even send you a written chip (~1.5 EURO) on the mail ,
7/16/2013 11:40:42 AM • ASUS A9RP... • Answered on Jul 16, 2013
2answers
My Asus get no power
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
1/28/2013 4:11:00 AM • ASUS A9RP... • Answered on Jan 28, 2013
Acess a9rp bios
What about the bios?Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Bios drivers.
4/20/2012 12:01:38 PM • ASUS A9RP... • Answered on Apr 20, 2012
0answers
Disassembly
Be the first to answer 8/7/2011 5:47:49 PM • ASUS A9RP... • Posted on Aug 07, 2011Be the first to answer
My keyboard keys f h
The internal connections for that key are on the same data column - it means that this column has failed. This is unfixable, you must replace the keyboard.
http://www.gemwon.com/ShowProduct.aspx?ID=812
7/18/2011 4:23:09 PM • ASUS A9RP... • Answered on Jul 18, 2011
0answers
Pushing start button will not boot up laptop
this issue could mean you have a dead battery and may need to buy a new one or you have a dead main board, have you tried having the laptop on A/C power and have the battery out of the laptop?
1/1/2011 10:10:58 AM • ASUS A9RP... • Answered on Jan 01, 2011
The DVD drive is not being recognized by the
hi jelly. i am happy to assist you, this is the link to download all your drivers
http://www.asus.com/product.aspx?P_ID=ikR9WFshwKXUg4Fc
just select your OS to download your drivers, but jelly i think DVD drive is inbuilt in PC or laptop used to regoginesed it automatically , i think there is some connection problem in your dvd drive better check it using hardware eng. that's more safe friend.
Good luck ! if you think your problem solved don't forget to rate
12/31/2010 5:40:09 AM • ASUS A9RP... • Answered on Dec 31, 2010
I can hear a sound
If this is a sound coming from within the laptop, I suggest it be taken apart by a computer technician and either the CPU cooler be replaced or it needs to be cleaned of dust. Laptop noise from inside is not a good thing, it should be relatively quite. However some-times you will hear the CPU fan speed up to cool the processor and then quite down again.
damnor01
11/14/2010 8:11:21 AM • ASUS A9RP... • Answered on Nov 14, 2010
ASUS A9RP Notebook Logo
50 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
acess a9rp bios
  • Computers & Internet
