20 Most Recent Acer Aspire 5000 Notebook Questions & Answers
There is no legal download of Microsoft Office for free. However, there is a free Office suite available that supports all of the Microsoft Office files. You can find it at: www.Openoffice.org
Acer Aspire 5000... | Answered on Aug 07, 2015
there is a great chance that you knead to service your laptop.the thermal compound on the laptop cpu must be removed properly and reply every 3-6 mouths max. drop me a mailo on my facebook at nic fourie if you wanna no how to service your laptop
Acer Aspire 5000... | Answered on Dec 20, 2014
It basically means the battery has outlived it's use and can no longer hold a charge. Even though the charger is hooked up you will still need a new battery to get away from this problem. Once the new battery is installed and charged this error should disappear. Hope this helps.
Acer Aspire 5000... | Answered on Aug 17, 2014
You might have a faulty keyboard or a key may be continuously pressed without you seeing it physically. When you get to that screen again, try running your hand across all the keys a few times and see what happens. If not, just go on ebay and find a cheap one and replace it.
Acer Aspire 5000... | Answered on Mar 03, 2014
Hi.
Does your home have a wired or wireless network?
Acer Aspire 5000... | Answered on Dec 09, 2013
The password was set by the owner of the drive.
Acer Aspire 5000... | Answered on Nov 16, 2013
Try inserting the Windows Cd and resetting the administrator password
Acer Aspire 5000... | Answered on Nov 12, 2013
Have you tried turning the router off and on?
check the password.
check to make sure that your network card drivers are installed, if you are not sure, go to the manufacturuers website and find driver downloads section. they will be in there
Acer Aspire 5000... | Answered on Nov 11, 2013
Just for what it's worth, I use the site devid.info for drivers. It has a driver agent as well which will scan for drivers too if needed (it's the only driver "Scanner" that works that I've found). That said, I searched for that device and could not find it on that site.
This driver is on the Acer website for Windows XP. http://global-download.acer.com/GDFiles/Driver/Audio/Audio_RealTek_5.10.0.5273_XPx86.zip?acerid=633638101827496299&Step1=NOTEBOOK&Step2=ASPIRE&Step3=ASPIRE%205610&OS=X02&LC=en&BC=ACER&SC=PA_6
It should work, if not, send me an email to gensupportjsebean@jsebean.com and I'll try to get back to ya!
-Jonah
This time you buy a Genuine Windows Operating System Disc.
Acer Aspire 5000... | Answered on Nov 10, 2013
the best way is your consult ONLINE via chat to the ACER company, in order to clarify the status 4 disks.
God bless you
Acer Aspire 5000... | Answered on May 25, 2013
Break it off..........
In order to take the Base Enclosure (Bottom Cover) off, you would have to break it off.
The Acer Aspire 5000 series of Notebook PC's, disassembles from the Top down. When you are done you are looking at an empty Base Enclosure,
http://www.ebay.com/itm/ACER-ASPIRE-3000-3004-ZL5-5000-LAPTOP-BOTTOM-CASE-COVER-LOWER-BASE-3AZL5BATN05-/181127078788
You have to;
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Remove the Harddrive Compartment Cover, Harddrive, Memory Compartment Cover, Ram Memory, Wireless Module, Wireless Antenna wires out of laptop body, Optical Disk Drive, (DVD drive), Display Assembly, (LCD Module), Keyboard Cover, Keyboard, Palm Rest Cover, Motherboard, and so on..........
Then you have the Base Enclosure. (Bottom Cover)
WEAR an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Acer Aspire 5000 series of Notebook PC > Service Manual (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Go to the paragraph that starts with Aspire 1200. (1200 in Blue)
Drop down to the 6th line (4920G), scroll across; and click on the blue -> 5000
For additional questions please post in a Comment.
Regards,
joecoolvette
Acer Aspire 5000... | Answered on May 02, 2013
hold the mouse pointer on icon and drag it to where you want it
or right click on screen select the view arrange icons
Acer Aspire 5000... | Answered on Feb 19, 2013
Enable the wireless adapter in Device Manager. If you need the driver, select your OS: http://support.acer.com/product/default.aspx?modelId=37
Acer Aspire 5000... | Answered on Feb 07, 2013
What happens when you load IE? Try to reboot the laptop, unplug, remove battery, plug in, reboot.
Acer Aspire 5000... | Answered on Dec 10, 2012
You probably have a mbr virus..
Download The following iso listed below. It is the latest version of the Kaspersky rescue disk. You need to burn it to a CD with a program like Imgburn (Which is also FREE like the iso file). Then you need to boot from the CD and run the scanner. It should fix you right up.
Kaspersky rescue cd download:
http://majorgeeks.com/downloadget.php?id=6501&file=1&evp=ef4247319d4b536cb88b74d1ae4842b0
Imgburn download:
http://majorgeeks.com/downloadget.php?id=4870&file=15&evp=0636b68877cb69b15faa3374cb1dcd89
Acer Aspire 5000... | Answered on Sep 03, 2012
Imgburn download:
enter 3 time wrong password ..u will see 5 digit code send me code ill u password ..
Acer Aspire 5000... | Answered on Aug 14, 2012
Acer Aspire 5000 Notebook Logo
140 questions posted
Ekse
Alun Cox
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
acer 5630g error
  • Computers & Internet
