20 Most Recent
Compaq Evo N400C Notebook Questions & Answers
WHAT DO I DO TO MY COMPAQ EVO N400C TO GET IT TO
It should have no problem ,,connect vga to vag out the back,,of evo,,should work,,also the compaq website is very helpful,,support and driver downloads for everymodel,,goodluck
Pentuim 3 prosser
No, it isn't possible, the pentium 3 and pentium 4 are different designs, each one needs a special motherboard and chipset made for each model.
Wont boot
First, check to make sure there is no disk in the CD drive or the floppy drive, if the computer has a card reader, check to make sure there is no memory card in it. If all of that is clear, I am afraid you might have bought a computer which does not have an operating system (Windows XP/Vista, Mac OS, Linux, etc.) on it. If this is the case, you would need to purchase an operating system... but here is the thing... by the time you pay for an operating system in the store or on line, you might as well buy a new computer as operating systems run about as much (as far as price goes) as a cheap computer does.
Thanks for using the FixYa forums!
Compaq EVO N400C PC Notebook Problem
your laptop should function even without a battery. Remove the battery you just bought and see if only with AC adapter, would your laptop turn on?
If not, then try removing the memory and see using a pencil eraser, clean the contacts of the memory and see if you can power your laptop with only ac
Evo n400c
Did you charge it for up to 8 hours?
Caring for your Compaq Evo N400c Laptop Battery
You can improve the life of your Compaq Evo N400c Laptop Battery by doing the following:
When
you first receive your laptop battery charge it fully for at least 6-8
hours and then discharge the battery fully by using your laptop
unplugged from the mains until it runs down completely.
Repeat this 3 times to ensure your Compaq Evo N400c Laptop Battery will give you the maximum performance.
If
you regularly use your Compaq Evo N400c Laptop on mains power for
extended periods, removing the battery from your Laptop during these
periods will extend the usable life of your laptop battery.
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
I want to install xp on compaq nx 6310 give the procedure with pendrive
2006 PC (HP.coM) 16 years old.. ouch.
XP (microsoft) is now a horrible virus magnet, and there is ZERO support now, are you using the last XP earth 2020???
gee google that. 2001 to 2007 was XP rein , vista 2007
I bet there are 1millons of web site still with XP usage .(old topics)
google them. but Microsoft purged theirs.
it is not sold at all, so how in the world can you get the installer on any pen drive, and XP installed from CD not pen..
worst of all XP installer, can not us 99% of all USB ports and then only half after the install (unless you force them via F6 and floppy drive with xp drivers on the floppy for THIS PC)
to use any relic PCs run LINUX> not XP
