20 Most Recent Toshiba Satellite P105-S6207 Laptop Questions & Answers
Dell Inspiron n7010 to restore factory settings
2/23/2016 12:39:48 PM • Toshiba... • Answered on Feb 23, 2016
How to restore a dell inspiron e1505 without cd
try this on dells website.
11/29/2014 11:22:36 AM • Toshiba... • Answered on Nov 29, 2014
How to restore a dell inspiron e105 without cd
try this on Dells website. Knowledge Base
11/29/2014 11:22:09 AM • Toshiba... • Answered on Nov 29, 2014
Color lines and dark parts
I had a Toshiba Satellite and it developed the same colored lines problem. It will continue to deteriorate until you cant see any thing behind the lines. I found it to be a bad video card. Problem is....the video card (in most if not all Toshiba's of those days) is integrated into the mother board and can not be replaced separately. You must replace the mother board to correct the video card problem. Due to the expense, I'd rather buy a new PC and have the data trans'd to the new PC. ------------------------bp
6/2/2014 1:23:58 PM • Toshiba... • Answered on Jun 02, 2014
8answers
Vertical lines in my laptop screen
There could be three different possibilities why you would get a line on your lcd display.
First, it could be a missing signal from the controller IC to LCD driver IC
Second it could be a defective LCD driver IC itself
Third it could be a dry contact in the tape carrier package ( TCP).
Attach an external monitor to your laptop and make it your primary display unit to see if you are still getting the lines if not its you TCP if you still get lines it will need to have either the LCD IC or the controller IC checked and possibly replaced.
6/2/2014 1:11:31 PM • Toshiba... • Answered on Jun 02, 2014
Im trying to locate the Toshiba link to link me to
Did you launch a Google search ? Anyway here is a link to the Toshiba support site.http://support.toshiba.com/
10/16/2013 10:37:11 PM • Toshiba... • Answered on Oct 16, 2013
How do i get f8
This is not enough information to answer. What exactly are you trying to do?
10/14/2013 8:06:22 PM • Toshiba... • Answered on Oct 14, 2013
I have a Toshiba Satellite
If you hav enot changed any software on the pc (like the drivers or new video software) the video controller may be bad an need replacement. If you are not familiar with doing it, try a repair shop, it may be more close to the cost of / or more expensive than replacing the laptop.
9/4/2013 7:30:52 PM • Toshiba... • Answered on Sep 04, 2013
How to restore my inspiron
THERE IS NO SHORTCUT TO RESTORE A PC LIKE MOBILE DEVICES.BUT YOU CAN UNINSTALL THE UNWANTED THINGS BY GOING TO CONTROL PANEL>PROGRAM AND FEATURES AND THEN CHOOSE THE PROGRAMS YOU DON'T NEED. 2)OR YOU CAN SIMPLY REINSTALL OPERATING SYSTEM .THIS WILL MAKE YOUR SYSTEM A FRESH NEW SYSTEM LIKE YOU BOUGHT IT NOW.
7/22/2011 5:24:25 AM • Toshiba... • Answered on Jul 22, 2011
2answers
Toshiba L30-101 i want to
Press F8 as it boots, that will give you access to the rescue/restore start up system; assuming it has not been deleted from your partition.
2/13/2011 12:29:19 PM • Toshiba... • Answered on Feb 13, 2011
I have a problem with
Consult the MFR of the game - they may provide a patch file. You can also re-install Directx from the Microsoft Update website.
10/28/2010 12:56:45 AM • Toshiba... • Answered on Oct 28, 2010
How to reset my dell
Do you have problems with a Dell inspiron or with a Toshiba Sattelite?
You'll have to use the CD/DVD that was shipped with your laptop.
Put it in your drive and boot up with it.
Some models have a recovery program and you'll have to burn the CD or DVD first.
9/22/2010 7:01:23 PM • Toshiba... • Answered on Sep 22, 2010
My laptop keep shutdown by
Try to take the battery out *Remove main supply, *Hold power button down for 30 secs, *Put only power supply in, do not put battery in *Turn laptop on *Put the battery in.
If it works for you than its great else it is a hardware problem with your laptop. Your laptop turns off due to high heat.So, if the above solution doesn't work then take to a hardware shop.
Good Luck!
6/26/2010 3:28:14 AM • Toshiba... • Answered on Jun 26, 2010
Satellite P105-S6207 Laptop Computer (PSPADU01600S) PC Notebook: Many multicolored vertical lines on screen. I drop...
Same problem. many multicolored vertial lines on the screen, but I haven't dropped it.
6/11/2010 10:39:40 PM • Toshiba... • Answered on Jun 11, 2010
What do i do to restore my inspiron 1501 to
You can restore to factory setting by follow these step
  1. Restart your laptop
  2. Press f5 or f6 button much times (rapidly) to run recovery wizard in recovery wizard ,select and click on recover c: driver
note : DO NOT click on "restore completely my system" because all data in youre hard disk will be deleted (delete all partition's) & not complete restore . Only click on restore c: drive
hope it help and hav a nice day
regards
4/15/2010 1:08:26 PM • Toshiba... • Answered on Apr 15, 2010
Everything on my toshiba computer is enlarged how
Adjust your display resolution settings Go to Control Panel Click on Display or Appearance Click on Settings Tab Adjust the resolution to the highest level.
12/5/2009 5:00:58 AM • Toshiba... • Answered on Dec 05, 2009
Restore to factory settings
Shut down the system, restart the system when system rebooting type F8 fallow screen direccions
11/17/2009 6:59:36 PM • Toshiba... • Answered on Nov 17, 2009
Toshiba Satellite P105-S6207 Laptop Logo
93 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
everything toshiba computer enlarged
  • Computers & Internet
