20 Most Recent Fujitsu LifeBook N6100 Notebook Questions & Answers
Having a problem installing new memory. I'm not
Make sure to open up the RAM compartment and pull out the memory sticks. Once you pull out the memory sticks, be careful to replace the memory sticks properly as the previous memory sticks were located before you removed them. If you are unable to do that, then you may need to take it into a shop for a professional to place the sticks in properly.
11/19/2009 6:29:28 PM • Fujitsu LifeBook... • Answered on Nov 19, 2009
Spilled liquid on laptop keyboard
Search for a keyboard on eBay. Should be about $5-15. Type in "(model name) keyboard."
3/14/2009 9:27:29 PM • Fujitsu LifeBook... • Answered on Mar 14, 2009
2answers
Five vertical lines have appeared (one at a time over a 8 week
It sounds like the flex ribbon cable has become loose from the connector on the motherboard. You might just try pressing firmly on the middle top of the keyboard or near where the hinge is located to see if the lines go away. If they don't then you might have to disassemble the Lifebook just enough to get access to this cable and see if it is loose.
2/10/2009 5:04:22 PM • Fujitsu LifeBook... • Answered on Feb 10, 2009
Over the past 8 weeks, a series of five vertical lines have
You Will Need A Display Replacement..
The Circuit Board Attached To The Back Panel Of Your Display Is Failing.. This C-Board Is Not Repairable and is integrated into the Display screen panel. And Yes, They Will Get Worse... They Multiply, They'll Start Moving Up And Down and Left And Right, You Will Eventually Get A Blank Screen..
2/6/2009 3:40:11 AM • Fujitsu LifeBook... • Answered on Feb 06, 2009
Fujitsu Laptop. Pls Help for my laptop that turns on with no display and only blinking num lock light.
Question edited for proper spelling of maker name and better English. Question moved to Fujitsu category. No model, service tag details given, so generic help. Re: E744 - NumLock flashing Remove the battery and the ac adapter and press the power button again for a view seconds. After that connect the ac adapter first an try again if you can start your device. If you are facing the same problem again you should contact a service partner regarding a repair of your notebook. May 5, 2015
E744 - NumLock flashing - Fujitsu Support Forum
Fujitsu https://forum.ts.fujitsu.com > forum > viewtopic
Fujitsu S6520 screen blank with Num lock blinking
Fixya https://www.fixya.com > support > t5988599-fujitsu_s... Press and hold the power button for 30 seconds solid. Then, do not put the battery back in, just the power cord. Try to start the computer, if it starts, ...
6/27/2023 5:46:18 PM • Fujitsu LifeBook... • Answered on Jun 27, 2023
2answers
The build in microphone not working, it used to work
Try a hard shutdown if the volume is up.
5/4/2019 6:45:21 PM • Fujitsu LifeBook... • Answered on May 04, 2019
Need help
your problem could be that the hard drive is broken, perhaps with some tool to repair hard disks the problem. test starting for example hiren boot from a memory or cd and see if it recognizes the hdd, if so you can pass some repair tool
11/21/2017 8:04:40 PM • Fujitsu LifeBook... • Answered on Nov 21, 2017
0answers
How can i reset bios code ?
remove the bios password by removing the cmos battery, removing the jumper from the pins right next to the battery, marked something like pswd, plugging it in and hitting the start button.Before you open the case, unplug, remove the bettery, then hold the start button to get rid of any energy.
5/14/2016 10:32:36 AM • Fujitsu LifeBook... • Answered on May 14, 2016
Location of cmos battery
please mention the laptop model
4/29/2016 2:54:51 PM • Fujitsu LifeBook... • Answered on Apr 29, 2016
How do I reset administrator password on startup?
In the bios
3/18/2016 7:00:12 AM • Fujitsu LifeBook... • Answered on Mar 18, 2016
Keyboard
Sounds like liquid may have been spilled on the keyboard. Plug in an external usb keyboard and check if it works. If so, you will need to buy a replacement keyboard and swap it out, best cheap from Ebay.
12/6/2015 6:48:27 PM • Fujitsu LifeBook... • Answered on Dec 06, 2015
How do I retrieve cursor which has disappeared on fujitsu lifebook
1) Try plugging in an external usb mouse incase you have disabled the mouse pad by mistake 2) Force a reboot and press F8 just past the BIOS screen Choose Last known good configuration from the list
12/6/2015 6:45:57 PM • Fujitsu LifeBook... • Answered on Dec 06, 2015
Where is reset button on fujitsu lifebook
Google search your manufacturer make and model and the word manual. If one is available, you can find it in the search results.
4/1/2015 12:48:36 PM • Fujitsu LifeBook... • Answered on Apr 01, 2015
Show me a picture of the location of the reset button
Google search your manufacturer make and model and the words reset button location. You can find it in the image search results. You could also try the manual, which should show the location.
4/1/2015 12:36:24 PM • Fujitsu LifeBook... • Answered on Apr 01, 2015
2answers
My fujitsu lifebook T4215 says that the wifi has been turned off. How do I turn it back on? It seems to imply that there is a button to hit but I can't find it...
Normally there is a hardware switch on the side of the laptop Sometimes you can press on the keyboard some buttons like this - Activate by pressing FN (on same line as spacebar in blue) and then a button that looks similar to this one. 25617748-cbt13vi4zbmnff1d5zdl02jb-2-0.jpg
3/30/2015 9:46:38 PM • Fujitsu LifeBook... • Answered on Mar 30, 2015
Where is my print screen button
Often you find it at (or towards) the right top area. This is not possible to confirm without knowing what computer/keyboard/Operating System you use. It may be abbreviated as "PRT SC" or similar and often is in connection with an Alt key. If you have a dedicated Numbers keypad it should be to the top of that. For better answer please ask with more details.
3/2/2015 5:29:58 PM • Fujitsu LifeBook... • Answered on Mar 02, 2015
How do I turn off numbers lock on Fujitsu Lifebook e sereis
Hi According to the manual which I found available for download here: File description there is a button on the keyboard marked "num" and this toggles the virtual number pad on and off. I cannot however find a diagram, or any indication in the manual as to where on the keyboard this button is. Hope this is helpful, if so would you please register that with Fixya Cheers
2/16/2015 12:49:26 PM • Fujitsu LifeBook... • Answered on Feb 16, 2015
FUJITSU -LH530
c:\users\wbscve~1\appdata\local\temp\msohtmlclip1\01\clip_image001.gif1. Click on start menu. 2.Type cmd in search field. 3.Right click on cmd file and click on Run as Administrator.It is must to run commanod prompt with administrator privileges. 4. Type SLMGR -REARM (SLMGR is Windows software licencing management tool. REARM command will reset the licencing status of machine) and press enter as shown in screen shot. 5. Now a confirmation window will be opened, click on OK. 6. Restart your PC. Now you will never receive error message. Enjoy the windows 7 like original windows 7. As you are not using original windows, you are not authorised to update windows. If you update windows, Microsoft will install one file which can detect your window is genuine or not. So follow the below steps to switch off windows automatic update. 1. open control panel. 2. Go to windows update. 3. Click on "Install updates automatically(Recommended)". 4. Select "never check for updates(Not recommended)" Before using above methods, you were getting error "this copy of windows is not genuine", that means your windows has updated file which can detect your windows OS. So You must uninstall the update which was detecting your windows. Follow the below steps to uninstall windows update. 1. Open control panel. 2. Go to windows update section. 3. Click on view installed updates. 4. After loading all installed updates, check for update "KB971033? and uninstall. 5. Restart your PC. We must use above mentioned three methods to get error free windows. Still if you are getting problems, then download, re install windows 7 and follow above steps. Then you will never get "this copy of windows in not genuine" error. I hope you like my article about "This copy of windows is not genuine". If you got benefit from my article, do me favour by sharing this article with your friends. And if you want to receive more articles in your Email, kindly Subscribe to Whatvwant.com by Email.
2/12/2015 3:33:37 PM • Fujitsu LifeBook... • Answered on Feb 12, 2015
Fujitsu LifeBook N6100 Notebook Logo
11 questions posted
Top Fujitsu Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
LifeBook Fujitsu
  • LifeBook Fujitsu
Most Popular Question
spilled liquid laptop keyboard
  • Computers & Internet
